sfatelier Posted October 7, 2009 Share Posted October 7, 2009 The edit handles on objects are suddenly missing. I can move objects but can no longer lengthen or shorten, etc. What happened? Thanks! Quote Link to comment
Pat Stanford Posted October 7, 2009 Share Posted October 7, 2009 Check the mode of the 2D selection tool. It is probably set to Disable Interactive Scaling Mode (first one diagonal arrow with a red circle with a line through it. The default for switching modes is the U key. Hit the U key a few times to step through the options or use the mouse to click the mode you want. Or you might have multiple objects selected and the second mode (Single Object Interactive Scaling) selected. 1 2 Quote Link to comment
sfatelier Posted October 7, 2009 Author Share Posted October 7, 2009 You were absolutely correct. I must have accidently clicked that option. ThankS!!! Quote Link to comment
vodsonic Posted October 29, 2009 Share Posted October 29, 2009 Hmmm... I had the same problem here, and had tried everything I could think of to get the edit handles back, including clicking the different interactive scaling mode buttons on the tool bar. It wasn't until I used the "U" key, as Pat Stanford suggests above, to cycle through the interactive scaling modes that the edit handles actually returned. I wonder if this is a Snow Leopard-related bug in my case. Quote Link to comment
Ray Libby Posted October 29, 2009 Share Posted October 29, 2009 In recent versions the Selection Handles are only there when you are using a tool that can interact with them. For instance, when the line tool is active you won't see selection handles. Quote Link to comment
vodsonic Posted October 30, 2009 Share Posted October 30, 2009 Makes sense. But I was using the 2D and 3D selection tools, and before I tried cycling selection modes with the "U" key, the only handle I could get on a line was the one to move it - there was no dynamic length adjustment available. This kind of thing is absolutely maddening when one is trying to meet a deadline. Quote Link to comment
SamIWas Posted November 29, 2009 Share Posted November 29, 2009 (edited) I just ran into this same issue, and none of the solutions above are doing anything. We have tried individually clicking the interactive scaling modes, and have tried pressing the U key to cycle through them. Nothing brings back the selection handles. Have tried quitting and restarting. Nothing. I even opened a new document, drew just a plain rectangle, and still...no way to resize. Some option somewhere must have gotten triggered, but it's beyond me which one. This is on VW 2010 w/ spotlight on Leopard. UPDATE: Restarted, reinstalled Vectorworks from scratch...and it STILL is not working! What the hell? What could possibly have happened to make the selection handles disappear completely?? I noticed that SmartPoints are also very small and hard to deal with suddenly... Edited November 29, 2009 by SamIWas Quote Link to comment
neworld Posted March 30, 2016 Share Posted March 30, 2016 I have wasted years on this problem with a drawing that wouldn't edit lines and finally saw the solution after trying the U fix above (didn't work). However, I noticed that the 2D selection tool no. 1 with the red no-access symbol, so clicked the 2nd one and voila! Would love to post the screen shot but no can do. Good luck to anyone if they ever read this fix and didn't die waiting... Quote Link to comment
henry kitchell Posted February 28, 2017 Share Posted February 28, 2017 if vectorworks has inadvertently placed any of your objects on a 3D Plane, you won't be able to see, much alone edit, any handles. under object info palette, refer to 3rd item down "plane:" which must be set to "screen" Quote Link to comment
Taproot Posted March 1, 2017 Share Posted March 1, 2017 I've run into this issue before and found that simply quitting and restarting VW solved the problem. Quote Link to comment
