sfatelier
Content Count
194 -
Calendar
Everything posted by sfatelier
I just started using 2017 and noticed that when I add a viewport to a sheet later, it automatically comes with a label. I have not been able to find a way to delete this label. Would appreciate any solutions as I don't need to label every viewport. Thank you. I"m working on a MacBook Pro
I agree but that did the trick. I'll now have to change it with every old file I convert I guess. Thanks for your help Mike!
I just installed v2015 (Architect and Renderworks) and when I opened a 2014 file, I tried to change my view to FRONT View, but what I get is a rendered perspective in a camera-like view. It also happens in RIGHT and LEFT views as well. Any suggestions? Thank you. I'm on a MacBook Pro.
I find that the borders of the printable are on the sheet are not consistent. How do I adjust these borders on Vectorworks Architect. V2014, Mac Mavericks OS. Thanks!
Thanks for your help! I did find the culprit. The camera view was not taken in the correct view. Once I returned it to the TOP/PLAN view from TOP, everything rendered just fine. So, the process is still the same. Now I'll have to fiddle with all of the new adjustments!
I have just upgraded to 2014 and when I try to update a viewport to a rendered drawing, all I get is a black image. I've done this hundreds of times before but now I'm baffled. Is there something different in 2014 vs. 2010? Thanks!
Yay, that did it! Thanks so much! Dean Shibuya
Thanks! I'll try that!
I erased the background in a photo in Photoshop and when I import it into Vectorworks 2014 to create an image prop, the transparent portion appears a solid white when rendered. What am I missing? Thank you!
Yes I am. Interestingly, other files where this wasn't a problem now won't render in the viewport as well. it renders fine in the drawing file but not the sheet file.
I have a viewport with the camera view on a sheet layer. Everything looks fine but it won't render. Any suggestions? Thank you.
I'm pretty sure it is. Can you extrude something that is NOT closed?
I have created a complex shape with various lines and curves and extruded the result. I have applied a texture but it won't render. What am I missing? Thank you!
I have two roofs (one flat and on hip) and for the flat roof, the top is transparent when rendered and on the hip the fascia is transparent. Can yo think of a reason why this is happening? Thanks!
Thanks! That did it!
I know the link layers command was deleted in 2010 but I can't figure out how to view all the levels in 3d. I only see the active layer. I heard about design layer viewports but so far have not been able to figure out how to do it. Can anyone help? Thanks!
Hello, I can't seem to find downloadable blocks for ADA signage (Restrooms, etc) for inclusion in my drawings. Does anyone know if this is hidden somewhere in VW 2010's resources, or an online source? Many thanks! Dean
Drawings Temporarily disappears in Sheet Layer
sfatelier replied to sfatelier's topic in Architecture
No, it's when I zoom or try to modify anything in the sheet layer. When I go into the viewport design layer, everything is fine. -
I am finding that when I try to make any changes (moving, editing) to viewports in a sheet layer, the whole thing disappears, then after awhile, it reappears again. Is there a reason why this is doing this? Thanks!
When I'm trying to compose viewports in a Sheet View, the entire drawing disappears until I scroll or zoom after awhile. It is very disrupting and adds a lot of time as I try to put sheets together. Any ideas what is causing this? Thanks! Vectorworks 2009, Mac 10.5
Show/Snap/Edit Option on Design Layers not Available
sfatelier replied to sfatelier's topic in General Discussion
Thanks all, especially Gideon. It was the "stacked layers" that disabled the command. -
Thanks, I tried that (aligned views, top/plan view) and I'm still having the same problem. -
I seem to have lost the option of editing in multiple layers. There is no problem doing this with classes. Is there an option command that will restore this? Thanks Vectorworks 2009 Architect/Renderworks Mac 10.5
Thanks, I'll try both and see which one I can get to look best.
Edit handles on objects suddenly missing
You were absolutely correct. I must have accidently clicked that option. ThankS!!!
