BLM Posted October 6, 2008 Share Posted October 6, 2008 Why do some grouped objects not change after revising class characteristics in the Organisation Box? Am having trouble with changing the colour of grouped objects on the same layers and viewports. Tried ungrouping and regrouping individually etc. Can change in OIP manually but want a global change across layers obviously. Also.......... why do some colours not print in B and W?? Greens, Yellows and and light greys especially. Ideas? Quote Link to comment
M5d Posted October 6, 2008 Share Posted October 6, 2008 Check that the elements within your groups have their attributes set to class in the attributes palette and that they are on the same class you are changing. It's a good idea to keep your attributes set to class as much as possible so that they respond to global settings & VP over-rides. Quote Link to comment
bonus Posted October 7, 2008 Share Posted October 7, 2008 (edited) Well - I have a similar problem. I want to assign a class to all doors and consequently have them change to the by class color. The easiest way is to select all doors and move them to the right class in the OIP. They switch to the right class but the color does not change. In the class orgzr the "use at creation" is checked. This is if I move more than one at a time. If I move them one by one it works, this has nothing with the door settings, groups or similar to do. ...another bug? This problem occurs in a 2008 file opened in 2009. I tried a clean 2009 file with just a couple of walls and some doors. Then there is no problem. So the 2008/2009 compability must be poor. Edited October 7, 2008 by bonus Quote Link to comment
Pat Stanford Posted October 7, 2008 Share Posted October 7, 2008 Have you tried the Update Plug-Ins or Reset Plug-Ins options on the Tools Menu under Utilities? Quote Link to comment
BLM Posted October 8, 2008 Author Share Posted October 8, 2008 Thanks it was simply not in all groups having the set to class tab checked! Not sure about the compatibility issues between 08/09. Quote Link to comment
bonus Posted October 10, 2008 Share Posted October 10, 2008 Man....I was really happy when I found an error: doors weren't by class. Quickly changed them all to "by class" in both pen and fill. Checked the class settings and looked fine. Selected three doors and moved them from one class "0" to the right one....but big dissapointment! - still no color change. Even worse! now the color won't change if I move one single door at a time, with or without "by class" settings. Quote Link to comment
bonus Posted October 10, 2008 Share Posted October 10, 2008 ...I also tried using the eyedropper tool with only pen style, fill style and class selected. Line color does not change. Quote Link to comment
