Guest FlowMaster Posted July 21, 2008 Share Posted July 21, 2008 Trying to figure out to have the field (background)in black and the walls appear white? I'm in 12.5...anyone have a sense of how to do this...can't seem to figure it out!? I would like ot do this for a presentation (brochure and website). Thanks so much! Daniel Quote Link to comment
gmm18 Posted July 21, 2008 Share Posted July 21, 2008 Use walls w/ white fill, Create your viewport as usual, Then draw a rectangle on the sheet layer, give it a black fill & send to back. Export pdf. Quote Link to comment
D Wood Posted July 21, 2008 Share Posted July 21, 2008 Vectorworks>Preferences>Display>Black background will get you a black screen, then you use white lined and filled walls. Hard on the eyes though in my opinion. Quote Link to comment
gmm18 Posted July 25, 2008 Share Posted July 25, 2008 DWood, exporting a PDF with this the "Black Background" Preference still results in a white background with dark line output. Quote Link to comment
Benson Shaw Posted July 30, 2008 Share Posted July 30, 2008 It's not intuitive, but: Set VW pref for black background. Render and print/save to pdf, and the black background shows in the pdf. If all you need is the linework, remove fill and change line color of rendered objects to white. And it's weird: 2d objects, like the text and leader lines in my example, print/save as white when they have line color black. Unfortunately, you can't see them in the rendered DL unless they are selected. (but they are visible in the pdf save!) And it's Strange: Hidden Line renders do not preserve the black background. ?! yikes, now I'm really confused. -B Quote Link to comment
maarten. Posted July 30, 2008 Share Posted July 30, 2008 (edited) If you have Photoshop (or any other program of that kind), you can just draw your drawing in VW like you always do (white background, black lines) and set it to "negative" in PS. An other option: when you're on windows, you can create a new layer on top of your drawing, set its layer transparenty to "Photo-Negative" and draw a black rectangle on that layer... Should be the same effect normally. I'm not completly sure about that last methode, for i haven't used it for many years (last mac version where that was in was VW11, so.... ) Edited July 30, 2008 by maarten. Quote Link to comment
mike m oz Posted July 30, 2008 Share Posted July 30, 2008 - Use the Black Background option for VW. - Then Export Image File. Quote Link to comment
gmm18 Posted July 30, 2008 Share Posted July 30, 2008 ahhh, thanks Mike. That seems to be the quickest solution, without having to change the way you work in VW or do any work in some other application. Quote Link to comment
