Palettes scattered
Does anyone have this problem:
Every few days when I open VW08 alway palettes are in a different location than when I left them. For exmaple I have my OIP palette on my left hand side and set to quite wide, sometime when I open VW it is 50% off the screen and shrunk. It seems to happen mostly with palettes that are not floating.
Sounds like it may be corrupted workspaces. Why/how they get corrupted is beyond me. Try removing the offending workspace from your VW preferences folder:
Windows:
C:\Documents and Settings\\Application Data\Nemetschek\VectorWorks\2008\Workspaces\
Macintosh:
/Library/Application Support/VectorWorks/2008/Workspaces/
Then restart VW. This will force VW to re-open the default workspace in the application folder.
Yep, it was corrupted.
With a pallet covering the entire screen I couldn't draw anything.
And it appears that overlapping all the other pallets confused the application loading and led to the long...10 minute...load times.
I started closing/resizing pallets and figured it out...which saved time over rebuilding the custom workspace.
If I hadn't figured it out, I'd have been dead in the water all day.
Deleting the workspace would have been a real pain.
This sort of problem (and the proposed solution) doesn't create a positive perception of Vectorworks...even though you did respond and I didn't call tech support about it.
I'm reasonably tech savvey, but for many people this type of anecdote could be a deal breaker.
Thanks for your help. I do appreciate it.
  • 5 months later...
Hi,
I have this same problem in connection with a wider VW crashing problem. It is so bad that I maintain a second workspace as a back up and a shortcut on my desktop to take me there!
I am running in a Windows XP environment (yeh I know I should buy a Mac - build a bridge).
Does anyone have any suggestions re a constant crashing issue with VW 12.5.3?
Cheers,
Iain
Are you plugging in an additional monitor/projector by any chance?
The resolution of the computer screen and the additional monitor may be mis-matched.
It could be a video card failure?
You should have one workspace for the computer and a different one for when you are using the additional monitor.
