Jeffrey W Ouellette Posted May 20, 2008 Share Posted May 20, 2008 Doug, Email me the file. Quote Link to comment
boxjoint Posted May 20, 2008 Share Posted May 20, 2008 For those who don't want to dig around in Jeffery's worksheet for the trick, here it is. I cannot get this trick to work. I've added the column with formula =COUNT and used the column reference in my formula =(Window.RoughOpenWIdth)/D4 but the summed cells are still not correct. 47'7 7/8" / 15 should return a value of 3'2 1/8", not 8'8 7/8". Any suggestions? Does this trick only work with VW 13? Quote Link to comment
Pat Stanford Posted May 21, 2008 Share Posted May 21, 2008 Boxjoint, I just tried this and it does seem to be broken in VW12. I have not been able to figure out exaclty what is happening, but the calcs are definitely not right. In VW2008, I did find that it does not work correctly if the field you are summing on is the field that you are trying to do the calculation on, but that does not help in VW12. Sorry, Pat Quote Link to comment
boxjoint Posted May 21, 2008 Share Posted May 21, 2008 Pat, Thanks for checking it out in V12. It's beyond my comprehension that after 20 years in business, this package cannot produce a window schedule without a lot of fussing around. Quote Link to comment
Jeffrey W Ouellette Posted May 21, 2008 Share Posted May 21, 2008 For version 12, try moving the COUNT column in front of/before the width and height columns. Quote Link to comment
boxjoint Posted May 21, 2008 Share Posted May 21, 2008 Jeffery, Thanks but... Count is in column D. Width and Height are columns H & I. I am summing column E. Still getting the wrong answers. I tried moving Count to the column immediately preceding the width and height but it didn't help either. Other thoughts? Quote Link to comment
Jeffrey W Ouellette Posted May 22, 2008 Share Posted May 22, 2008 Bug submit. http://www.nemetschek.net/support/bugsubmit.php Quote Link to comment
I F A Posted July 17, 2008 Share Posted July 17, 2008 Along the same lines of what Pat and Visard were discussing on 3/19, my doors don't show any of the info from the PIO on the door record. "On schedule" is checked for each door. Any thoughts? Quote Link to comment
gmm18 Posted July 17, 2008 Share Posted July 17, 2008 IFA: Check your Worksheet "Criteria" Right-click on the Database Header...then: Note this is useful because say you have a few different design scenarios that you created by duplicating a design layer so you can have a bunch of alternatives to look at. In this case you can set one of the criteria to be "Layer-Is-Design Layer X." Of course there are numerous other ways that this may be useful. This level of flexibility is also probably one of the reasons that Schedules in VW is not as "automatic" as you might expect, but it proves to be a great benefit to have this amount of control at your fingertips. Quote Link to comment
Yancka Posted July 21, 2008 Share Posted July 21, 2008 For what stands PIO or OIP? Quote Link to comment
Guest Wes Gardner Posted July 21, 2008 Share Posted July 21, 2008 PIO - Plug In Object OIP - Object Info Palette Quote Link to comment
visard Posted July 21, 2008 Author Share Posted July 21, 2008 PIO = Plug-in object OIP = Object Info (information) Palette Quote Link to comment
