mdarch Posted February 8, 2008 Share Posted February 8, 2008 Now that everyone is used to viewports, isn't it time to dump layer scales? Why not just make all layers 1:1 as per many other CAD programs, and use viewports to control the output. I can't really see the point of different scaled layers now, in fact I tend to set them all to one scale (except perhaps the site plan, but then i have to layer link it in ...) I think it would make it easier to set up drawings etc. Any reasons to keep them? Quote Link to comment
islandmon Posted February 8, 2008 Share Posted February 8, 2008 You're joking .. right ; ) Quote Link to comment
Pat Stanford Posted February 8, 2008 Share Posted February 8, 2008 Everyone uses the program differently. It is never, Never, NEVER wise to suggest taking anything out, because there will be a large minority who use whatever feature you think is not needed. As to why layer scales, the best reason to keep them (in my opionion) is so you can draw WSYWIG (What You See Is What You Get). You get a much better idea of how your model will look when printed at 1/4" if you draw it at 1/4". You can see what line weights work well and what don't and you can see if there is room to squeeze in that extra note or detail without having to go back and forth to a sheet layer. Pat Quote Link to comment
Ray Libby Posted February 8, 2008 Share Posted February 8, 2008 Where did you hear that everyone is using viewports? I don't on every set of drawings. Quote Link to comment
D Wood Posted February 8, 2008 Share Posted February 8, 2008 I hardly ever use viewports, so eliminating scales would really stuff up the way I work. Mdarch, if you want to only have layers at 1:1, fine, go ahead, you can do it now, but you don't need to force everyone else to use the program the same way you do. Quote Link to comment
jan15 Posted February 8, 2008 Share Posted February 8, 2008 Even in Autocad, which has had viewports for 20 years, and which has never had layer scale or design layers, there are plenty of people who don't use viewports. Quote Link to comment
michael john williams Posted February 8, 2008 Share Posted February 8, 2008 No, this is not a good idea. Normally our layer scales are the same scale as our vps to enable to simply work with the page layout. The programme needs to have maximum flexibility for users using it differently. I would suggest that the majority of users do not use vps. Quote Link to comment
Dieter @ DWorks Posted February 8, 2008 Share Posted February 8, 2008 Reasons for not getting the scales out: 1) I have met many architects and 90% of them have never used a viewport. They all draw in design layers with different scales so they can put all the stuf next to each other at the right position for printing. 2) When you set you're layer's scale to the scale you normaly print, you can see how the lineweights and hatches will look (if you check this option in the preferences). 3) If you want to make a quick print, you can set the layer's scale, set the page and print. 4) There are maybe other reasons for not getting them away Quote Link to comment
