laldenj
VectorWorks 2008 only partial plotting
After clean install on XP Win workstation running HP DesignJet 500 plotter, am only getting a cropped image printing on 24x36 sheets. Even the border alone will self-crop to about 70% of sheet width, deleting the entire title block and some of the plot in the process.
11 answers to this question
A bit more info on this bug.
Identical border prints fine from within same operating system to same printer when working from VectorWorks 12.5. Also, smaller sheet sizes up to C size work fine from VW 2008 but fail at larger plots.
If rendering is moved to right 20% of sheet while in D plot, nothing prints. If same rendering is dragged to center of D plot, entire image will print.
Very weird.
Do you have "one printer page" selected in the Print Dialog as the page size?
In page setup dialog box, 1 page horiz and 1 page vert. is selected. Printable area is shown as 34.66 width and 23.61 height.
In printer setup box, Arch D 24x36 is shown, landscape is the orientation, and scaling is 100%.
In properties, roll feed(24 in) is selected. Normal quality, optimize for drawings/text, and landscape orientation are selected.
All are my usual settings. All print same border fine when done from VW 12.5 but not in 2008.
Go to File >Page Set up
In the upper right corner, check mark "Choose Page Size Unavailable" and choose "One Printer Page" in the drop down box.
When you view the drawing, are the desired printed objects within the gray print boundary border?
With that option checked as you recommend, there is no change in erratic plotting behavior. Again, within gray'd printing area, nothing prints if in the right-most 20% of page(the print file processes, spools, and then self-deletes). Only when objects are beyond this range does the print file become registered with the plotter and then what prints is a cropped image, ommiting the right side of sheet.
So far, only workable option is to export file as PDF, then print from Acrobat.
Help!
Did you download & install the latest printer driver from HP's website?
You nailed it!
I unchecked this pref(it was checked by default)and plots are now complete. Thanks much.
.......and what is that pref(GDI+)?
I had the same problem and unchecking the GDI thing seemed to work but am I just imagining things or does it print slower now.
It sounds like GDI is a useful thing to *have* checked. Is this a bug?
Thanks,
Pat
I have the same problem and switched off the GDI. The full plot printed but the symbols (ones with less than 100% opacity)would not show what was beneath the symbol. The symbol also looks different than the same symbol with 100% opacity.
Thanks
I have the same problem. My plotter only prints half the page and crops everything on the right hand side of the page! I tried unchecking the GDI but it still doesn't work.
