Heather S 0 Posted June 29, 2007 I have two windows set into a wall. Is there a way to get rid of the wall line in between them? Quote Share this post Link to post
Robert Anderson 129 Posted June 29, 2007 Use the "Custom Sash" option to make a double-wide sash window. Quote Share this post Link to post
Dieter @ DWorks 24 Posted July 1, 2007 or make them a group, and delete the line Quote Share this post Link to post
P Retondo 111 Posted July 1, 2007 That line is a zero-thickness jamb. Use Robert's advice by going to the "Settings" window - you will get good results. If you convert the PIO to a group, you will lose the 3d information. Quote Share this post Link to post
Jonathan Pickup 286 Posted July 1, 2007 custom sash is the way to go. Setting a custom sash and then editing it lets you choose the size of the sashes individually. Not as good as WinDoor (www.ozcad.co.au) but still good. Quote Share this post Link to post
rsa 1 Posted July 4, 2007 Hi Johnathan, I've just recently seen the windoor site and was wondering if it lives up to the website description. What do you think? Sounds like you recommend it. Also I have a remodel project right now with old curved windows in an arc-ed bay. Do you know if windoor can create a window that follows an arced path? Thanks -Rob Quote Share this post Link to post
dontevenjoke 3 Posted July 4, 2007 Windoor is fantastic, it has to be one of the best time saving additions to VW. I am in Australia and VW ships with Windoor, but the other day I mistakenly used the door tool and was shocked at the difference. Windoor is well worth getting. Quote Share this post Link to post
