chstech Posted December 25, 2006 Share Posted December 25, 2006 What is the best way to make a chain link fence? i need to make a 6' high fence line with posts spaced every 20'. It also has a 12' swinging door section. AND of course in 3d. I did a search in the fourms and have not found much. Thanks Quote Link to comment
CipesDesign Posted December 25, 2006 Share Posted December 25, 2006 Use extruded circles for the posts. Then extrude a very skinny reatange (or maybe even a line! for the actual fence. If you search through the "metal" textures you will find something (probably) close enough for the actual chain link (try the "metal-stainless steel mesh" turned 45?, and adjusted for size/scale). Use it on the extruded fence... Good luck, have fun & Merry Christmas! Quote Link to comment
Vectorworks, Inc Employee Robert Anderson Posted December 25, 2006 Vectorworks, Inc Employee Share Posted December 25, 2006 If the posts don't need to be circular, you might consider using a [no kidding with the name] chain extrude object. Draw a vertical line for the chain-link part first, then draw a rectangle for the posts. Give the vertical line a grid texture from the Renderworks procedural textures. Quote Link to comment
chstech Posted December 26, 2006 Author Share Posted December 26, 2006 I have already created the fence i need by the painstakingly process of extruding, polylines, and 45 deg rotations. I unfortunately cannot use the line extrude with texture for two reasons, 1- with this extrude you cannot see thru the fence, 2- most of the drawings i work on we do not render and therefor the texture would not show up. I was hoping there was a Fence Tool much like the Wall Tool that would make life simple. Especially when desgining landscape, what do most people do?? Create a fence from scratch? I know you can make a Roadway & a Guardrail, but no fence? Please tell me i am wrong. Robert, maybe this is something that can be on the "In The Near future" list. Thanks Quote Link to comment
Petri Posted December 26, 2006 Share Posted December 26, 2006 Drew - Until a Fence Tool is available, create the fence in 2D like this: - front view - rectangle with no fill - "bucket hatch", ie. Hatch command - extrude rectangle and hatch by, say, 5 mm Quote Link to comment
chstech Posted December 26, 2006 Author Share Posted December 26, 2006 Petri, That might work but unfortunately i need 3d. Insert my sad face here. Quote Link to comment
mike m oz Posted December 26, 2006 Share Posted December 26, 2006 chstech - read Petri's last post again. His method does work. All you need is a 45? cross hatch that has no background fill. Quote Link to comment
Petri Posted December 27, 2006 Share Posted December 27, 2006 It does indeed - except that I forgot the important step of ungrouping the hatch. I have somewhere a simple "fence tool" that creates a series of vertical 3D-polygons of given height based on mouse clicks in any view (also plan with 3D-loci as the bottom-rail or post reference). Another version makes walls in the same fashion. Theoretically I could probably make a modern path object based on those, but I don't for the time being have a need for one myself and no-one wants to pay for anything... Besides, a certain Mr. NNA might just copy the idea and include it in the next release of VW. Quote Link to comment
