Splitting a 3D object
Go to Top or Top/Plan and use the Split tool.
Or draw the arc and set the fill to none. Draw a line between the arc end points. Select the arc and the line and Compose. Then Extrude.
Or create an extruded rectangle that starts across the arc and encloses the entire curved part of the arc. Select the arc and the box and Intersect Solids.
Or probably a half dozen other ways.
  • Like 4
  1. draw rectangle (stage)
  2. draw arc (curved thrust)
  3. select both
  4. right click > add surface
  5. (menu bar) AEC > Floor...
that will give you a hybrid object that looks good in plan view
also check out the stage plug tool if you need more options (could help downstream with documentation)
