  • 1
Cabinet Shelves
4 answers to this question
Hi Rudy,
If your configuration is using a False Drawer / False Door, you can achieve that in VW 2024 update 4 (builds later than 736395).
The following issue was fixed: "Removed separator under top-most face item if it is a False Drawer / False Door".
Is that the case?
  • Like 3
I had the exact same issue the other day.   I solved it by creating an extrude over the shelf then using the subtract solids command to remove the shelf.
I like that the cabinet tool in 2024 has greatly improved from previous versions.
When does 2024 update 4 come out I don't see it as available yet.
