jmhanby Posted February 22, 2024 Share Posted February 22, 2024 Is there a way to have only a partial guard rail on the stairs? I have a stair where the top half of the stair is next to a wall and the lower half is not. How do I make the guard railing stop at the wall but have the hand rail go the full length of the stairs? Quote Link to comment
zoomer Posted February 22, 2024 Share Posted February 22, 2024 I think this is not possible. But as VW Stair handrails often does not meet users expectations anyway, many switch Stair handrail off and use the separate Railing Tool to add these separately. 2 Quote Link to comment
E|FA Posted February 22, 2024 Share Posted February 22, 2024 Or model in 3D with the following shortcut: Build the Stair with the guardrail showing -> Duplicate the Stair -> Ungroup the duplicate -> delete/modify the parts of the resulting group you don't need ->turn the guardrail off on the original Stair. 3 Quote Link to comment
TomKen Posted February 26, 2024 Share Posted February 26, 2024 Are you using VW2024, if so this is easily done using the new railing tool in gravity mode. Something like this. 3 Quote Link to comment
jmhanby Posted February 27, 2024 Author Share Posted February 27, 2024 On 2/22/2024 at 3:30 PM, zoomer said: I think this is not possible. But as VW Stair handrails often does not meet users expectations anyway, many switch Stair handrail off and use the separate Railing Tool to add these separately. I tried this but couldn't get the railing to follow the angle of the stairs. Quote Link to comment
jmhanby Posted February 27, 2024 Author Share Posted February 27, 2024 On 2/22/2024 at 3:43 PM, E|FA said: Or model in 3D with the following shortcut: Build the Stair with the guardrail showing -> Duplicate the Stair -> Ungroup the duplicate -> delete/modify the parts of the resulting group you don't need ->turn the guardrail off on the original Stair. I will definitely try this. Thank you. Quote Link to comment
jmhanby Posted February 27, 2024 Author Share Posted February 27, 2024 On 2/26/2024 at 11:14 AM, TomKen said: Are you using VW2024, if so this is easily done using the new railing tool in gravity mode. Something like this. Thanks, I guess I need to start using 2024! Quote Link to comment
gfyfe Posted October 15, 2024 Share Posted October 15, 2024 @E|FA Am following your shortcut for this as I have the same issue, however when I ungroup it loses all 3D geometry and is just a 2D object. How do you get the separate handrail components that you are trying to model back into 3D? Thank you! Quote Link to comment
E|FA Posted October 15, 2024 Share Posted October 15, 2024 I just did a test. If you ungroup in a 2D top view, it ungroups as 2D objects. If you ungroup in a 3D view it ungroups as 3D objects. I never knew this is how it worked. Quote Link to comment
zoomer Posted October 15, 2024 Share Posted October 15, 2024 5 minutes ago, E|FA said: If you ungroup in a 3D view it ungroups as 3D objects. Similar for Exports. If you want 3D, stay in a 3D View. But at one point someone from Vectorworks (Landmark ?) mentioned you must be in Top Plan View to export a 3D. Since then I am a bit confused .... Quote Link to comment
gfyfe Posted October 15, 2024 Share Posted October 15, 2024 Ah, thank you so much! 1 Quote Link to comment
