jmhanby
15 -
Reputation
0 NeutralPersonal Information
Location
United States
Recent Profile Visitors
Does anyone have a base cabinet that will render hidden in Vectorworks 2022.
Since there is a bug in Vectorworks 2022 and we have to make all objects solid in order to render hidden line, some windows are not showing in the solid wall. How to fix this? We have tried deleting the windows and reinserting them, not made them solid but they are not showing up. Any help would be appreciated.
Can someone tell me where I might find a 24" range in 3D. Can only find one in 2D.
I am having the same problem in all views. Changing items to solid fill corrects the problem. I don't recall doing this in version 2021.
Thank you! That is what I needed!
Is there a setting so I can see the different line weights on the screen? Right now I have to print to pdf to see the line weights to make corrections in the file.
I got it. Go to organization layout and click on references.
The architect used to use a really old version (98 or older, can't remember exactly) and is being forced to upgrade. I am new to vectorworks and it is my job to help him transition to the newer version as well as drafting so I am learning the program as I go along. I downloaded the files to work with in the new version.
I am working with an architect remotely and we use drop box to share files. When I get files from the drop box, I always get the attached message. How do I fix this so I won't get the same message every time I open a file?
Thank you for the response! I was just using the Architect workspace and found the different stair tools under the Architect/BIM workspace. I was able to make the stairs correctly however now I can't edit the handrail! Always something. 🙂 What is the difference between the workspaces and why wouldn't the handrail edit like in the other stair mode? So much to learn!
Is it possible to angle a column to use as a decorative support? I tried making a polygon in elevation view but it will not let me extrude it so I thought I could use a column but can't figure out how to angle it.
Thank you all for the responses! I am using version 2021 and I don't see where I am able to change the style of the stair. I have looked at all the settings.
How should I model an exterior concrete stair and landing where the concrete goes all the way down to the ground? I modeled the stair using the stair feature however it angles the bottom of the stair like a stringer. I thought about modeling it with the push/pull feature but am not sure how to do the sloped railing.
Vectorworks 2021 - how do I show an infill at a demolished door and window? New vectorworks user here coming from Revit. In Revit the wall automatically infills.
Hello all, Newbie to Vectorworks here, using Vectorworks Architect 2021. Can someone tell me why the viewport is clipping off part of my model and how do I fix it? Looking forward to learning this program to it's fullest and interacting with you all. :)
