window and door appearance in top plan
Hello,
When I place a door or window in the wall - there is an issue - the caps of the wall turn to be thin on the plan.
Is there something wrong with the window settings?
In object Info - Full break with caps and Full break without caps - it's the same on the top plan.
I use Vectorworks 2017.
Thank you
Tatiana
The issue is not with the wall, but with your 2d window settings.
I am using VW 2024 and can't exactly remember in VW2017 if it is totally the same, but if you click on the settings option for the window, you will see you can choose '2d visualizations' and set the thickness of your choice for the window (or door).
Check the screenshot below:
I agree this is quite annoying, I gave up on trying to find a solution.
I can see from Kevin's image that you could match the Jamb's lineweight to the wall, but this would effect the entire jamb rather than just the junction between the jamb and the wall which I imagine is what Tatiana is trying to show.
