Theo D Posted December 14, 2023 Share Posted December 14, 2023 (edited) Hello everyone, When I make a section or an elevation with the clip cube to send as a viewport in a presentation board and I make dimensions of my section or elevation directly in my drawing layer, the dimensions don't appear in the viewport and I end up having to dimension my sections or elevations directly in the viewport. Is there a solution? Thanks for your help! Edited December 14, 2023 by Theo D Quote Link to comment
line-weight Posted December 14, 2023 Share Posted December 14, 2023 4 hours ago, Theo D said: Hello everyone, When I make a section or an elevation with the clip cube to send as a viewport in a presentation board and I make dimensions of my section or elevation directly in my drawing layer, the dimensions don't appear in the viewport and I end up having to dimension my sections or elevations directly in the viewport. Is there a solution? Thanks for your help! Some people will disagree with me on this, but your dimensions should be in the annotations space of the viewport, not in the design layer. You can get away with in 2d drawing but it doesn't make sense in 3d. In the case of a section - where are you locating your dimensions in the design layer? The section doesn't exist as snappable geometry in a design layer, the cut plane only gets drawn in a viewport. 2 Quote Link to comment
Theo D Posted December 14, 2023 Author Share Posted December 14, 2023 Thank you for your reply. I'm placing my dimensions correctly in relation to my section but they don't appear in the viewports. This would be very useful to me, not in perspective but in orthogonal section to avoid drawing it in 2D afterwards when it exists in 3D. Thank you Quote Link to comment
line-weight Posted December 14, 2023 Share Posted December 14, 2023 50 minutes ago, Theo D said: Thank you for your reply. I'm placing my dimensions correctly in relation to my section but they don't appear in the viewports. This would be very useful to me, not in perspective but in orthogonal section to avoid drawing it in 2D afterwards when it exists in 3D. Thank you I think you might need to attach some screenshots or an example file because I don't really understand where you are putting the dimensions that are disappearing. Quote Link to comment
Jonathan Pickup Posted December 14, 2023 Share Posted December 14, 2023 for this type of drawing, i recommend that you place your notes and dimensions in the annotations part of the viewport. Quote Link to comment
Ramon PG Posted December 15, 2023 Share Posted December 15, 2023 On 12/14/2023 at 5:34 AM, Theo D said: Hello everyone, When I make a section or an elevation with the clip cube to send as a viewport in a presentation board and I make dimensions of my section or elevation directly in my drawing layer, the dimensions don't appear in the viewport and I end up having to dimension my sections or elevations directly in the viewport. Is there a solution? Thanks for your help! Your VP might not have the Dimensions class active. I agree you should place them in Annotations. Quote Link to comment
