cberg Posted October 16, 2023 Share Posted October 16, 2023 There appears to be a bug in VW2024. You cant reshape floors with the Reshape Tool without double clicking into the shape. If you happen to reshape the floor the selection handle moves but the floor does not. There are also snapping issues, that I need to explore. May be problems on my end. If you do try to reshape, the floor gets corrupted and cannot be selected. VW 2023 does not work this way. I will submit this as a bug. Reshape floor problem.vwx 1 Quote Link to comment
cberg Posted October 23, 2023 Author Share Posted October 23, 2023 I am still talking with Tech Support Premium to get this submitted as a bug. Quote Link to comment
cberg Posted October 24, 2023 Author Share Posted October 24, 2023 Apologies for the rather clunky screen recording, but here is a quick video documenting the issue. Screen Recording 2023-10-24 at 9.39.48 AM.mov Quote Link to comment
line-weight Posted October 24, 2023 Share Posted October 24, 2023 I never use "floors" but can replicate this. @cberg a tip for using quicktime screen recorder; you can stop the recording by clicking on the little stop button in the top bar. 1 Quote Link to comment
Tom W. Posted October 24, 2023 Share Posted October 24, 2023 What I noticed was that you can 'uncorrupt' the Floor by entering the edit mode for the base Rectangle then exiting again. But definitely needs attention. Thanks for raising it with VW @cberg! Ironically you can reshape it fine using the Selection Tool (in VW2023 a Floor doesn't have reshape handles unless the Reshape Tool is activated). I have just tried my first project in VW2024 + have noticed that Roofs aren't clipping Walls properly so reverting to VW2023... (will file bug). Another QuickTime tip: Edit > Trim allows you to trim excess frames off the end. 1 Quote Link to comment
cberg Posted November 22, 2023 Author Share Posted November 22, 2023 This problem was not fixed in 2024 Update 2. Quote Link to comment
jaseweil2 Posted November 29, 2023 Share Posted November 29, 2023 I have discovered another glitch in 2024 with Floors. Several times now after I create a floor, I am unable to select it with the selection tool. The only way to select it is to create a script to select all floors. This is very frusterating. Quote Link to comment
david on orcas Posted May 20, 2024 Share Posted May 20, 2024 I have noticed that this still hasn't been fixed. I will try to submit as a bug too. I created a worksheet to try to select the broken floor via worksheet. It is interesting that when the floor breaks, it reports a location of 0,0. broken floors with worksheet for floor hunting.vwx 1 Quote Link to comment
cberg Posted May 20, 2024 Author Share Posted May 20, 2024 Thank you. The problem also happens when you make Roof Faces. (Rectangles seem to be the culprit). Quote Link to comment
cberg Posted July 18, 2024 Author Share Posted July 18, 2024 Sigh... Service pack 6 and this bug has not been fixed. Quote Link to comment
