rudybeuc@gmail.com Posted September 29, 2023 Share Posted September 29, 2023 What could be causing the behavior depicted? I can't get a text edit box. Really tried to figure this one out before posting... Thanks, Rudy Beuc 2023-09-28 19-29-25.mkv Quote Link to comment
0 rudybeuc@gmail.com Posted September 29, 2023 Author Share Posted September 29, 2023 BTW this also happens on my laptop which is Windows 11. Quote Link to comment
0 Pat Stanford Posted September 29, 2023 Share Posted September 29, 2023 No real idea. Could it be on a different layer and you have the Layer Options set to Show Others? Or a different Layer Scale? Quote Link to comment
0 rudybeuc@gmail.com Posted September 29, 2023 Author Share Posted September 29, 2023 Nope, that those don't seem to be it..... Rudy 2023-09-28 20-36-59.mkv Quote Link to comment
0 Pat Stanford Posted September 29, 2023 Share Posted September 29, 2023 From the movies I have no idea. Have you restarted the computer? Does this occur only in this file or in a new blank file? Try quitting VW, move your User Folder (preferences) to the desktop and restart VW. VW will create a new User Folder (and my ask for your serial number again). See if this solves the problem. If not, Quit VW, delete the new user folder and drag the old one back. What happens if you Alt-Drag across the text? That should select it even is only a small portion is touched. Can you post the file for us to take a look at? Quote Link to comment
0 rudybeuc@gmail.com Posted September 29, 2023 Author Share Posted September 29, 2023 Yeah, none of that worked. Oddly enough, I created a new file and it worked correctly... Here's the problem file. I'm going to explore this more throughout the day... Thanks, Rudy Beuc Text prob.vwx Quote Link to comment
0 Pat Stanford Posted September 29, 2023 Share Posted September 29, 2023 If one file is not behaving properly, then it must be something in the file. I would recommend either sending the file the VW Tech Support and see if they can fix the problem or to do a Layer by Layer copy to a new file and see if the corruption follows. I would not recommend just continuing with the file as is. If there is corruption it is likely that it could get worse. And make sure you have multiple backup/archive copies so if it does crash you don't lose everything. Sorry. 2 Quote Link to comment
0 rudybeuc@gmail.com Posted September 29, 2023 Author Share Posted September 29, 2023 I submitted it. Turns out that the text did not have any justification value set to vertical or horizontal in the OIP. Checking a box for those values brought back the select-ability of the text and the text edit box. They've entered this as a bug. Hadn't occurred to me to look at and try those values. I had figured the justification had matched the pick box location on screen. Kinda make me feel better that a bug was found... Thanks, Rudy Beuc 4 Quote Link to comment
0 Pat Stanford Posted September 29, 2023 Share Posted September 29, 2023 I'm glad it turned out to be a simple fix. And also glad that VW Tech Support was responsive. Quote Link to comment
0 Elite Exhibits Posted October 1, 2023 Share Posted October 1, 2023 For what it's worth ... Read this thread the other day, then proceeded to have #@!?#@¿! issues with text. The file in question was created in ACAD / imported so that does not help. Essentially text was selectable, yet invisible when attempting to edit. Especially true with text that was rotated. The OIP issue mentioned above was NOT encountered in this case. Solution was to copy / paste the text into a new drawing and edit - In some instances replacing the text was easier that the edit process. Make sure your FONTs are all good in the operating system. An alternate font alleviates many edit / VW issues with text. Change the fonts en masse when importing may be a good Workflow When ever VW gives me the font is to small warning I instinctively change the font. Peter V2021 / MacBook Pro M1 Max OS 12.6.7 Quote Link to comment
0 rudybeuc@gmail.com Posted October 2, 2023 Author Share Posted October 2, 2023 On 10/1/2023 at 7:17 AM, Elite Exhibits said: For what it's worth ... Read this thread the other day, then proceeded to have #@!?#@¿! issues with text. The file in question was created in ACAD / imported so that does not help. Essentially text was selectable, yet invisible when attempting to edit. Especially true with text that was rotated. The OIP issue mentioned above was NOT encountered in this case. Solution was to copy / paste the text into a new drawing and edit - In some instances replacing the text was easier that the edit process. Make sure your FONTs are all good in the operating system. An alternate font alleviates many edit / VW issues with text. Change the fonts en masse when importing may be a good Workflow When ever VW gives me the font is to small warning I instinctively change the font. Peter V2021 / MacBook Pro M1 Max OS 12.6.7 Hmmm..... Ws the imported text comprised ot true type fonts or *.shx fonts? Thanks, Rudy Beuc Quote Link to comment
rudybeuc@gmail.com
Thanks,
Rudy Beuc
10 answers to this question
