Jack2022 Posted July 19, 2023 Share Posted July 19, 2023 Hi All, another of my posts touched on this however it might help to separate the issue out. After some trouble and help from others I managed to get photos of plants to display in the plant schedule. Is there a way to get all the plant images to display as a grid? At the moment I can only get them in columns and if you repeat the column formula across subsequent columns the images just repeat. Thanks, Jack Quote Link to comment
Pat Stanford Posted July 19, 2023 Share Posted July 19, 2023 You will not be able to generate a grid using a worksheet. Actually you probably could do it manually, but definitely not using database rows. If you really want a grid display you probably need to look at the Graphical Legend object to do this. Quote Link to comment
Elite Exhibits Posted July 19, 2023 Share Posted July 19, 2023 @Jack2022 Here is some information for your perusal My 2¢ There are some issues - VW 2023 / SP6 appears to fix some things (see below)The coffeebreak is good, except what we have experienced as "problematic" is not directly covered in the discussion as some items are existing / pre-prepared. Peter Graphic Legend GRAPHIC LEGENDS . ANNOTATIONS HUGE PROBLEM!!! Graphic Legend Cell looks different in the edit mode compared to the sheet layer version ... https://forum.vectorworks.net/index.php?/topic/108998-graphic-legend-cell-looks-different-in-the-edit-mode-compared-to-the-sheet-layer-version/ Graphic Legend https://forum.vectorworks.net/index.php?/topic/101534-graphic-legend/ Graphic Legend summarize symbols https://forum.vectorworks.net/index.php?/topic/109139-graphic-legend-summarise-symbols/ Graphic Legend R-Values https://forum.vectorworks.net/index.php?/topic/108542-graphic-legend-r-values/ Graphic Legends https://forum.vectorworks.net/index.php?/topic/104060-graphic-legends/ Graphic Legend Coffee Break https://university.vectorworks.net/mod/overview/view.php?id=5180 Graphic Legend 2023 HELP https://app-help.vectorworks.net/2023/eng/VW2023_Guide/Annotation2/Graphic_legends.htm?rhsearch=graphic less&rhhlterm=graphic 2 Quote Link to comment
Jack2022 Posted July 20, 2023 Author Share Posted July 20, 2023 Thank you both. will explore this Quote Link to comment
