cberg Posted June 9, 2023 Share Posted June 9, 2023 I am trying to develop a graphic legend that shows the R-Value, and I am getting inconsistent results. I have defined the dynamic text via the wall's IFC Entity - Thermal Transmittance. In the wall style, I have set to override the calculated R-Value. Because I manually calculated. For some walls the values show up correctly. And others, they do not, and I can't figure out why. I don't think the .1 is a U-Value, because in other walls I get random numbers. Any ideas? As an aside, walls need a dedicated record format like other parametric objects. It is very difficult to locate their data. Test File2.vwx Quote Link to comment
Tom W. Posted June 10, 2023 Share Posted June 10, 2023 Try using the #WS_OBJRVALUE# worksheet function instead 1 Quote Link to comment
cberg Posted June 13, 2023 Author Share Posted June 13, 2023 Thanks @Tom W. That seems to have done the trick. Now I have to copy back all my annotations that disappeared when I made the change! 😖 1 Quote Link to comment
cberg Posted June 13, 2023 Author Share Posted June 13, 2023 (edited) I was having issues earlier. I had to reset the value a few times before my R-Value stuck. It finally reads 23... Edited June 13, 2023 by cberg Quote Link to comment
