Miss Posted July 5, 2023 Share Posted July 5, 2023 Hi, I'm a little confused on what's going on with my slabs. I have 2 issues: 1) In top plan your able to see my slabs but as soon as I go into a 3d view some of them disappear? Are they still there? 2) In top plan when you click on the slab you can see it says slab-locked (I have all my slabs locked) but in 3d view when I click on it, it says polygon (I made the slab using a polygon for context), so why does it keep converting back to a polygon in 3d but its a slab in top plan? Thanks for the help Quote Link to comment
_James Posted July 5, 2023 Share Posted July 5, 2023 1) What attributes do the slab components have? 2), perhaps the polygon didn't get deleted when you created the slab? There is an option that says something like "delete source object" and perhaps this was unchecked? Quote Link to comment
Tom W. Posted July 5, 2023 Share Posted July 5, 2023 Also, are the classes the Slab components are assigned to visible? Quote Link to comment
Miss Posted July 5, 2023 Author Share Posted July 5, 2023 (edited) 14 minutes ago, _James said: 1) What attributes do the slab components have? 2), perhaps the polygon didn't get deleted when you created the slab? There is an option that says something like "delete source object" and perhaps this was unchecked? 1) they are all top of component - fixed thickness slab 2) thank you. I was able to fix this problem by checking that 7 minutes ago, Tom W. said: Also, are the classes the Slab components are assigned to visible? yes their visible Edited July 5, 2023 by Miss Quote Link to comment
Miss Posted July 5, 2023 Author Share Posted July 5, 2023 Now I'm not able to see any of the slabs in 3d view? Quote Link to comment
_James Posted July 5, 2023 Share Posted July 5, 2023 4 minutes ago, Miss said: 1) they are all top of component - fixed thickness slab but do they have a solid fill when you check their graphical attributes? Quote Link to comment
Miss Posted July 5, 2023 Author Share Posted July 5, 2023 (edited) I have also tried to render the slab and no texture shows up! please help Edited July 5, 2023 by Miss Quote Link to comment
Tom W. Posted July 5, 2023 Share Posted July 5, 2023 Might be time to post the file... Quote Link to comment
Miss Posted July 5, 2023 Author Share Posted July 5, 2023 Also when adding a texture to some of the slabs, the slabs just disappear Quote Link to comment
Miss Posted July 5, 2023 Author Share Posted July 5, 2023 How do I do this 1 minute ago, Tom W. said: Might be time to post the file... Quote Link to comment
_James Posted July 6, 2023 Share Posted July 6, 2023 15 hours ago, Miss said: yes That's the overall slab object, but the slab has components - it may be that the attributes of the components are set to none. I agree with others though, post the file and someone will take a look Quote Link to comment
Theo Studio SA Posted August 15, 2024 Share Posted August 15, 2024 Hi, Was this ever resolved? I am having the same issue. My slabs were working fine in a file I created without using storys. I am trying to setup a practice template using the story function. I have copied info across and the slabs have disappeared from 3D view. The slabs are all at the origin ontop of each other but are in the correct place in 2D top plan view. Any suggestions would be very helpful. Thanks Theo Quote Link to comment
Tom W. Posted August 15, 2024 Share Posted August 15, 2024 3 hours ago, Theo Studio SA said: Hi, Was this ever resolved? I am having the same issue. My slabs were working fine in a file I created without using storys. I am trying to setup a practice template using the story function. I have copied info across and the slabs have disappeared from 3D view. The slabs are all at the origin ontop of each other but are in the correct place in 2D top plan view. Any suggestions would be very helpful. Thanks Theo Post a file + someone will look at it. Your problem sounds unrelated to the one here. Sounds like you need to look at the Layers the Slabs are on + the Z Ref/Z Off settings. Quote Link to comment
