Holly2779 Posted June 12, 2023 Share Posted June 12, 2023 Hi Team, Looking to present a drawing at 1:1 but it will need to go across two A0 piece of paper (it doesn't fit on a single A0 piece of paper) How can I do this? I tried custom paper size of the doubled A0 paper measurements but this could be potentially and issue when printing? Thoughts please? Holly Quote Link to comment
0 markdd Posted June 12, 2023 Share Posted June 12, 2023 If you have an A0 plotter attached to your computer, then just choose A0 as your paper size. If not, and most people don't and you want to print this to a pdf, then go to printer set up and set up a custom size with the dimensions of an A0 sheet of paper. Set it to Portrait. Then go back to the page set up dialog and choose Horizontal: 2 and Vertical: 1. You should have a sheet layer that is the size of 2 pieces of A0 paper. Quote Link to comment
0 Holly2779 Posted June 12, 2023 Author Share Posted June 12, 2023 Thank you for your response, below is the 1:5 drawing for a client (if this helps to see it). I have been asked to provide this as a 1:1 so they can print it on their A0 Plotter to get a 'real life' cut out. When I try to alter the print settings (custom paper size/ 1189 x 841) is automatically sets pages as shown in the below screenshot... if I change those.... it changes the paper size 😬 I am struggling! LOC001- RIGHT- HYDEWOOD SIGN - VER3 - 07.05.23.pdf Quote Link to comment
0 markdd Posted June 12, 2023 Share Posted June 12, 2023 Go to Printer Set up and make sure that you have A0 selected. thengo back to the dialg that you see above. In the dialog above select Horizontal: 2; Vertical 1, then press OK. You should be returned to your Sheet Layer page with 2 Pages side by side. These will represent 2 sheets of A0 Paper. Quote Link to comment
0 Ramon PG Posted June 12, 2023 Share Posted June 12, 2023 1. Make a Sheet layer with only the sign. 2. Try changing the Page Setup printer to Any Printer and creating a "paper" the size you need. Quote Link to comment
0 Holly2779 Posted June 12, 2023 Author Share Posted June 12, 2023 @markdd Thank you again for taking the time to explain, I have screenshotted the sequence you have suggested to try and illustrate a little better the issue I am having... Select A0 its coming up as landscape - so I have switch around the numbers..... as shown here... Then I change the horizontal to 2 and the vertical to 1..... Note it already changed the width of my paper... Now I hit ok and get this teeny paper.....(in the middle of my 1:1 viewports for illustration) go back to view the settings : Editing the page numbers overrides the size.....? @Ramon PG Thank you for your suggestion too, I have queried though if this will create a printing issue - if I create my own paper size (Double A0) will I have an issue when attempting to print it across an A0 plotter.....? I don't physically have one in front of me (nor have personally used one) so I am unsure wether it will happily chop my picture in half for me... Thanks again for the support H Quote Link to comment
0 markdd Posted June 12, 2023 Share Posted June 12, 2023 You have missed out on the Printer setup stage. 4 Quote Link to comment
0 Holly2779 Posted June 12, 2023 Author Share Posted June 12, 2023 (edited) aha! thank you, I have now followed this and can see the two A0 pages on my screen! Thank you very much! Edited June 12, 2023 by Holly2779 Quote Link to comment
0 markdd Posted June 12, 2023 Share Posted June 12, 2023 Export PDF Command. Then in the Export Range section select All Pages. 2 Quote Link to comment
Holly2779
Hi Team,
How can I do this?
Thoughts please?
Holly
8 answers to this question
