Christian Fekete Posted April 6, 2023 Share Posted April 6, 2023 Why can't I drag a door into a wall. I can insert from a create similar selection but not by dragging it. I think to remember that there is a setup that allows this but I can't find it. Thanks CF Quote Link to comment
Pat Stanford Posted April 6, 2023 Share Posted April 6, 2023 The Door will only cut the Wall when dragging if the tip of the mouse pointer is inside the wall when it is released. So don't grab the leaf or swing, grab the frame and make sure the pointer is over the wall and you should be ok. Quote Link to comment
Tom W. Posted April 6, 2023 Share Posted April 6, 2023 You also need this enabled: 1 Quote Link to comment
Christian Fekete Posted April 6, 2023 Author Share Posted April 6, 2023 (edited) Thank you guys Had a hard time finding these icons but I found these options once I inserted a window the traditional way. Once I selected the options above they became consistent options. Edited April 6, 2023 by Christian Fekete answered process Quote Link to comment
E|FA Posted April 6, 2023 Share Posted April 6, 2023 You're looking at the wrong side of the screen. With the selection tool selected, look at the tool settings on the top left side of the document window. 1 Quote Link to comment
