GatRed Posted December 1, 2022 Share Posted December 1, 2022 (edited) Hi, I’m working on an existing chalet in the french Alps. It has a particular structure with crossing pieces of wood. I don’t manage to make it with Vectorworks. How can I make the crossing of the walls without creating 2 different types of walls ? Did I missed something ? Or maybe that will be a Vectorworks enhancement ? thanks ! LUG-test.vwx Edited December 1, 2022 by GatRed Quote Link to comment
0 Tom W. Posted December 1, 2022 Share Posted December 1, 2022 I think the best you can do is offer up the left hand wall to the others + not join it + accept the faint line in between in Top/Plan I think wall/component joining could definitely be improved. You can spend ages messing around trying to get the configuration you want + often have to return to remake the connections when you find they've decided to come apart again. Wall End Cap is very useful for achieving particular details but again quite time consuming + doesn't work in your case (works in Top/Plan but not in 3D). Quote Link to comment
0 GatRed Posted December 1, 2022 Author Share Posted December 1, 2022 Thanks @Tom W.for your feedback. I think also that this tool can be improved. Quote Link to comment
0 line-weight Posted December 1, 2022 Share Posted December 1, 2022 Or... free yourself from the shackles of top/plan, set floorplans up as horizontal sections, have same classes/attributes merge in section, then you don't have to worry about VW sticking the "nibs" on without dividing lines. (I think, not at computer just now so can't check) Quote Link to comment
GatRed
Hi,
thanks !
3 answers to this question
