Ramon PG Posted November 9, 2022 Share Posted November 9, 2022 Why, if I am using the global door tag setting, does the tool ask me to individually click this dialog for each door number? Quote Link to comment
0 Ramon PG Posted November 9, 2022 Author Share Posted November 9, 2022 37 minutes ago, Ramon PG said: Why, if I am using the global door tag setting, does the tool ask me to individually click this dialog for each door number? Quote Link to comment
0 Tom W. Posted November 9, 2022 Share Posted November 9, 2022 Do you need to uncheck this: 1 Quote Link to comment
0 Ramon PG Posted November 9, 2022 Author Share Posted November 9, 2022 13 minutes ago, Tom W. said: Do you need to uncheck this: Thanks. Quote Link to comment
0 Ramon PG Posted November 9, 2022 Author Share Posted November 9, 2022 1 hour ago, Tom W. said: Do you need to uncheck this: Maybe you know the answer to this... How can I double click a Space Tag and have it edit the Space name? I double click it, the Edit Tag Data dialog appears, but it doesn't work. Quote Link to comment
0 Tom W. Posted November 9, 2022 Share Posted November 9, 2022 28 minutes ago, Ramon PG said: Maybe you know the answer to this... How can I double click a Space Tag and have it edit the Space name? I double click it, the Edit Tag Data dialog appears, but it doesn't work. It seems that if you use the '#11_Name#' parameter instead of '#11_NameDisplay#' you can edit the Space name via the Data Tag: I don't know what function of the '#11_NameDisplay#' parameter is: why you'd use it over the other one. Someone else will know. @Nikolay Zhelyazkov? Quote Link to comment
0 Pat Stanford Posted November 9, 2022 Share Posted November 9, 2022 Space.'11_Name' is are the values displayed in the Name popup in the OIP Space.'11_Space Name Cust' is the custom name that has been typed into the OIP. If you set the Space Names to Custom and then set the field to Space Name Cust you should be able to come up with a tag that will allow you to type in the name you want. But I have not tried it. Sorry for using Vectorscript Record.Field notation rather than the Data Tag # notation. 1 Quote Link to comment
0 Ramon PG Posted November 9, 2022 Author Share Posted November 9, 2022 21 minutes ago, Tom W. said: It seems that if you use the '#11_Name#' parameter instead of '#11_NameDisplay#' you can edit the Space name via the Data Tag: I don't know what function of the '#11_NameDisplay#' parameter is: why you'd use it over the other one. Someone else will know. @Nikolay Zhelyazkov? I tried '#11_Name#' and it doesn't work. Quote Link to comment
0 Tom W. Posted November 9, 2022 Share Posted November 9, 2022 5 minutes ago, Pat Stanford said: Space.'11_Name' is are the values displayed in the Name popup in the OIP Space.'11_Space Name Cust' is the custom name that has been typed into the OIP. If you set the Space Names to Custom and then set the field to Space Name Cust you should be able to come up with a tag that will allow you to type in the name you want. But I have not tried it. Sorry for using Vectorscript Record.Field notation rather than the Data Tag # notation. Of course thank you! '11_NameDisplay' is for when you are using a custom space name. Quote Link to comment
0 Tom W. Posted November 9, 2022 Share Posted November 9, 2022 2 minutes ago, Ramon PG said: I tried '#11_Name#' and it doesn't work. Show a screen shot of you Define Tag Field settings. It works for me. Plus the 'Name Display' version now Pat's explained it Quote Link to comment
0 Ramon PG Posted November 9, 2022 Author Share Posted November 9, 2022 7 minutes ago, Pat Stanford said: Space.'11_Name' is are the values displayed in the Name popup in the OIP Space.'11_Space Name Cust' is the custom name that has been typed into the OIP. If you set the Space Names to Custom and then set the field to Space Name Cust you should be able to come up with a tag that will allow you to type in the name you want. But I have not tried it. Sorry for using Vectorscript Record.Field notation rather than the Data Tag # notation. Space.'11_Space Name Cust' does not work, at least in my setup. Thanks. Quote Link to comment
0 Tom W. Posted November 9, 2022 Share Posted November 9, 2022 Just now, Ramon PG said: Space.'11_Space Name Cust' does not work, at least in my setup. Thanks. You need to use '#11_NameDisplay#' Quote Link to comment
0 Ramon PG Posted November 9, 2022 Author Share Posted November 9, 2022 6 minutes ago, Tom W. said: You need to use '#11_NameDisplay#' That's wha I am using, but editing the Worksheet does not edit the Space Tag and vice versa. Quote Link to comment
0 Ramon PG Posted November 9, 2022 Author Share Posted November 9, 2022 13 minutes ago, Tom W. said: Show a screen shot of you Define Tag Field settings. It works for me. Plus the 'Name Display' version now Pat's explained it Define Tag Field? Quote Link to comment
0 Tom W. Posted November 9, 2022 Share Posted November 9, 2022 I thought we were talking about Data Tags. This was your original question: 1 hour ago, Ramon PG said: How can I double click a Space Tag and have it edit the Space name? Quote Link to comment
0 Ramon PG Posted November 9, 2022 Author Share Posted November 9, 2022 13 minutes ago, Tom W. said: I thought we were talking about Data Tags. This was your original question: Yes, I originally started with a Door Tag question. Then I asked about how to use the Edit Tag Data dialog to edit the Space Worksheet. Same issue, but neither work for me. Quote Link to comment
0 Ramon PG Posted November 9, 2022 Author Share Posted November 9, 2022 1 hour ago, Pat Stanford said: Space.'11_Name' is are the values displayed in the Name popup in the OIP Space.'11_Space Name Cust' is the custom name that has been typed into the OIP. If you set the Space Names to Custom and then set the field to Space Name Cust you should be able to come up with a tag that will allow you to type in the name you want. But I have not tried it. Sorry for using Vectorscript Record.Field notation rather than the Data Tag # notation. It does work, but only Worksheet > Space Object > Space, but not the other way around, which would be the most useful. Maybe I copied/wrote it wrong the first time. I apologize, and thank everyone for you prompt replies always. Quote Link to comment
Ramon PG
16 answers to this question
