Ramon PG Posted September 23, 2022 Share Posted September 23, 2022 Why would these walls show differently? Same settings. I even select both and replace them with the same wall in the Resource Manager and still they show differently. I chose the Eyedropper and select all the Preferences and, still they show differently. Seems I will have to select and replace each of the hollow ones one by one. Quote Link to comment
Tom W. Posted September 23, 2022 Share Posted September 23, 2022 Are the component offsets definitely the same? 1 Quote Link to comment
Ramon PG Posted September 23, 2022 Author Share Posted September 23, 2022 3 minutes ago, Tom W. said: Are the component offsets definitely the same? That was it, thanks. But why won't it change/reset even when replacing it the way I tried? Quote Link to comment
Tom W. Posted September 23, 2022 Share Posted September 23, 2022 In the replacement options you have the 'Replace Heights' + 'Only replace default heights' settings which will affect what happens 1 Quote Link to comment
Ramon PG Posted September 23, 2022 Author Share Posted September 23, 2022 4 minutes ago, Tom W. said: In the replacement options you have the 'Replace Heights' + 'Only replace default heights' settings which will affect what happens Ah... the devil is in the details. Quote Link to comment
Tom W. Posted September 23, 2022 Share Posted September 23, 2022 I was blissfully ignorant of what these settings did for ages until @zoomer pointed them out! I still find it confusing figuring out whether i need to check 'default heights' or not but being able to change a wall style without mucking up a load of carefully set component offsets is really useful/important. 2 Quote Link to comment
Ramon PG Posted September 23, 2022 Author Share Posted September 23, 2022 34 minutes ago, Tom W. said: I was blissfully ignorant of what these settings did for ages until @zoomer pointed them out! I still find it confusing figuring out whether i need to check 'default heights' or not but being able to change a wall style without mucking up a load of carefully set component offsets is really useful/important. Super cool guy that Zoomer, he's helped me quite often, also. 👍 1 Quote Link to comment
shorter Posted September 23, 2022 Share Posted September 23, 2022 When editing or replacing walls, we recommend turning off all those buttons asking whether to replace heights, or class, etc. Once bitten, twice rejected. 1 Quote Link to comment
