Rolan Castaneda
21 -
Reputation
7 NeutralPersonal Information
Location
United States
Recent Profile Visitors
Vectorworks 2024 Update 4 Available for Download - UPDATE 4.1
Rolan Castaneda commented on JuanP's article in Tech Bulletins
Just updated. Editing anything to do with Tiles is now painfully slow. Please fix. -
That hits the nail on the head. I deal with this constantly. Not everyone was trained with the correct "drafting ethics", and for guys like us who were, it can be very frustrating. The only way to go is to set up drafting standards and get everyone trained on those standards. Get the Principal/CEO in involved and on board with enforcing drafting standards.
Separate Move / Copy commands...
Rolan Castaneda replied to jason schneider's topic in General Discussion
If this helps, I usually just set my Move settings to "move and duplicate mode" with 1 duplication. Then to copy, I have gotten used to just holding the option button (Mac). -
Worksheet Database Sub-Row Default Height
Rolan Castaneda replied to Rolan Castaneda's topic in General Discussion
I do have a template with all my rows set to .25 inches, however the database sub-rows are automatically generated when it reads the Record Format. If a new object matching the criteria is added, the new sub-row is automatically generated but its height is Autofit, as you said. I did some research and there used to be an option to set sub-rows heights to match the header row (see old pic below; grabbed from the internet). Vectorworks needs to bring this back. -
Anyone know how to change or set the default height of database sub-rows? Not only is it a waste of time having to manually adjust the row heights constantly, it could also be easily forgotten.
Anyone know how to change the default height of database sub-rows? Not only is it a waste of time having to manually adjust the row heights constantly, it could also be easily forgotten.
VW2024 Data Tags Text Alignment
Rolan Castaneda replied to Rolan Castaneda's question in Troubleshooting
I figured out the workaround, but I don't want to waste time editing all my existing data tag symbols with this situation when it used to work just fine in prior versions. I'll wait to use v2024 when this is fixed. Yes, I have a lot of data tags. Thanks for looking into this, and I hope it gets fixed in the next service pack. -
Sure. See how the "W" is no longer centered along the X axis? But if you edit the symbol, you'll see the center of the text is along the X axis, and its vertical alignment is set to Center. Data Tag Test.vwx -
Data Tag Vertical Text Alignment is defaulting to Top. If the Field Label is 2 lines high, vw24 is pushing the alignment to the top even though I have the vertical alignment set to Center.
Does anyone know how to equally space patterns of line types? This is driving me crazy. It's so ugly!
Copy whole class status and paste in view
Rolan Castaneda replied to Peter Z's topic in Vectorscript
I just save the view, and give it the same name as before. Then it will ask you if you want to replace the existing saved view. -
Yes. It found 50 files. But my VW project is still taking forever to open. I am able to open other VW projects except for one. I opened a backup from 2 days ago that opened in just 1 min and 20 sec. I caught up on everything I did before it "corrupted". I saved and closed. Then I tried to open it again, and it's stuck at Step 6 of 11 again. I believe it is the Callout Tool that is messing things up. Should never have updated to v2023. Everything was fine in v2022.
I'm still having this problem in VW 2022 SP6. I have created a Data Tag that is placed about 2800 times. Boss wanted the rectangle in that symbol to be thicker. The moment I click "Edit Layout", maybe half or more than half of the Data Tags revert back to the default. Some retain the data. Quite annoying. I can't use VW 2023 because of another issue with the callout tool text scale.
Preferences 3D Tab - Default 3D view Render Mode / View Projection
Rolan Castaneda replied to Elite Exhibits's question in Troubleshooting
I did not. Can you list the steps to do that?
