altoids
93 -
Reputation
1 NeutralPersonal Information
Location
United States
Cannot Launch VW 2016 on 2014 iMac with OSX 10.15.6
altoids replied to Ron Prochot's topic in Hardware
VW15 is not perfect and problem free running under Mac OS 10.15, at least it works. Apple gives developers years of warning before dropping a feature from software, so the lack of support cannot be only due to Apple. Perhaps VW is just being cautious, but it is difficult to understand how they could drop support for each of their last 5 releases within12 months of each release. My toaster has a longer service life. -
Well, there are a couple of strange things here. Strange 1: I find that VW15 has run on every OSX from 10.11 through 10.15 without any major problems. 10.15 broke VW16 which wont even launch. This perhaps suggests that it is not the Mac's OS that is causing the problem as older versions of VW work. Strange 2: The compatibility chart claims that VW is only supported for ~ 1 year on the MAC platform. From the Chart VW16 is only supported through Mac OS 10.12 (which Apple released in Fall 2016), VW17 is only supported through Mac OS 10.13 (which Apple released in Fall 2017), VW 18 is only supported through Mac OS 10.14, (which Apple released in Fall 2018), etc. This implies that there is only about a year's life in each release, which is surprising to say the least. -
Hard to believe that to fix each line I have to: 1. Double click the notes, 2. Click on the actual note, 3. Click the "Edit..." button (why can't I double click on the note...?) 4. Click the check box, ("Use first 42..") 5. Click "OK" (I can't even us the key as a shortcut, because VW assigns the to be part of the note. 6. Painfully repeat 2 through 5 for all the notes on the sheet, 7. Even more painfully repeat the entire exercise for all the sheets. To add injury to insult, there is nothing that appears after pressing the "Edit..." button that could't just as easily appear in the "Keynotes Manager:Keynotes List" of notes that shows in #2 above. The "Edit Notes" window is superfluous, as it merely duplicates the editing of the text, and only adds the title and the "Use 42..." option, which could appear in the "Keynotes Manager:Keynotes List" window. Just like the previous sentence, wasting time repeating the same thing, twice. Why the additional window? Why not select multiple notes, and then check one box. Boom. Sorted. Am I missing some faster way of fixing this?
Vectorworks 2016 is here, ask us anything!
altoids replied to Vectorworks - Admin's topic in General Discussion
Does 2016 provide a method for automatically referencing sections or elevations, and updating the tags when they move? For instance, if I have a section that appears on, say, sheet A401, and I move the section to a new sheet, say A402, does the reference to this section update, or do I still need to manually edit all the tags? In ArchiCAD, for instance, if I draw a elevation in a model, then place the "viewport" on a sheet, all the references tags to the elevation are automatically created and updated, bidirectionally, upon creation and relocation. Anything like this in VW16? -
Did the upgrade degrade the software's performance, or was your machine already spinning beach balls?
We have the same problem. We reported it about 2 months ago, still waiting for a resolution. Currently, we are TYPING (!) our keynote on the PDF drawing or using a text box. NNA asked me for the file, but has offered no fix, patch, etc. into the memory hole it went. Outlander, please let me know if you find a solution. We would be happy with 30 seconds. We have between a 5 minute and a "I-can't-take-it-anymore-force-quit" delay. Utterly unacceptable bug. We're using 2010, but the same bug appears is VW2011, and in multiple files on multiple systems. I've used VW for many years,worked through multiple bugs, poor implementations, etc, but this one is about to get us to dump the software, as we cannot meet our production deadlines b/c the software will not allow us to annotate our drawings. Its bad enough that the economy is awful, that construction is deeply depressed; on the few projects we have, we now have to fight Vectorworks as well.
When I place a new call out, it works as advertised. If I convert it to a keynote, VW thinks for about 10 seconds before I can use the machine again. "Break Notes Across Columns" is unchecked. This is happening only on newly created files, even if the file has no objects in it. It happens on multiple machines. If I open an old file, the keynotes show no slowdown upon editing or creating. Any way to make the new keynotes fast again? VW2010 SP4 installed, OSX 10.6.4.
Using the move by points command, I am instructed to "use the command key to select an object". This work, unless the CAPS LOCK key is down, which prevents any object from being selected. This happens on two different OS X machines, all latest versions. Is there a way to use the Move by Points with the caps lock down, and select an object?. (OS X 10.6.3 VW2010 SP3)
MY CALLOUT HAS BECOME WORSE AS WELL. IT CRASHES IF I COPY A CALLOUT FROM ONE SHEET TO ANOTHER, THEN TRY TO ASSIGN THE COPIED CALLOUT TO THE CORRECT SHEET (LEGEND). SPINNING BEACH BALL, THEN CRASH. OSX 10.6.3. I JUST COMPLETED A CLEAN INSTALL AND APPLIED SP3. IS THIS A KNOWN BUG? KNOWN TO VW, THAT IS.
Vectorworks 2009 display problems on Mac Pro
altoids replied to jallen-bgcbc's topic in Architecture
Zooming in 2009 with a 3D model on a Mac is horrible. After zooming in or out, the screen erases, waits a bit, then redraws, then flashes. Slower than 12.5. This is with a Mighty Mouse & nice new Mac. SP1 installed. Rotating is lightning fast, but zooming like this hasn't been acceptable since 1997. VW, you want us to upgrade for this? -
Nice discussion. Its great to see how many ways there are of solving a VW bug, I mean feature.
Don't upgrade yet. There is no reward for being the first to post about a new bug. Wait until at least the first point release (13.1) or the second.
A legacy bug? Please tell me you are joking. Monkey, now that software is distributed electronically, companies have fallen prey to using early adopters as testers. When the companies had to burn and ship software, updating was expensive. Now it is relatively cheap, so the QC suffers.
What 2008 forgot and 2009 has forgotton too
altoids replied to michael john williams's topic in General Discussion
Wake up and smell the coffee. You were not forgotten, but ignored. A company that makes a living from writing and upgrading software must choose what features to include and what to leave behind at each release. They do not forget, but make business decisions about what features will sell. For NNA it may have been the right decision. For me, it seems like the wrong one. I don't understand why VW/NNA doesn't focus on keeping their base happier. If we all liked the software, they'd have a sales force of thousands. But you have ParaSolids! Now you can flicker with better 3D capabilities. -
It is doable, as ArchiCAD does it, but I suppose VW management doesn't think it is important enough to do. I'd be happy to post images from ArchiCAD if you'd like.
