collins
36 -
Everything posted by collins
That tile repeats just as you have drawn in. Is there a way to include randomness to the layout so there is randomness to the overall tile.
Is there a way to create randomness in a tile? The beauty of stipple is that the tile can appear scattered (if that is what you are looking for). I'd like to incorporate the randomness within scattered leaves and grass textures.
Changes to master file don't automatically update the target
collins replied to cookci's topic in General Discussion
Hi Wes, Where can you set the file to update automatically when opening? That used to happen in VW 2019 but I haven't experienced this since using the VW 2021 Thanks -
By just using the keyboard, when using the move by points tool (duplicate) is there a way to access and enter a different number of duplicates in the toolbar box without selecting the current number with the mouse? Much like we use tab to enter the geometry of objects I would like to hit tab after choosing the duplicate tool. Thanks
Hi Boh, I have ended up doing the same and place each scale bar on each sheet at 1 to 1. It took a little while to figure out how to do it but works fine for now. Thanks
Hi Boh, can I ask how you ended up using scale bars in general after this discussion?
I can't find where this thread is to be upvoted, I guess because it's an old version? But is there a simple scale tool that doesn't require heading to the drop down menu and typing in etc etc. Also, it would be great that the scaling occurred from the point at which the measurements took place. As in you are scaling the object from a point rather than the object scaling to the new desired size but jumping into a random nearby position.
Hi Pat, can I ask where this thread you mention above moved to in the new site? Thanks https://techboard.vectorworks.net/ubbthreads.php?ubb=showflat&Number=210046Post210046
I have managed to create a tile of a pattern shown above which is a step closer. The way I have tried to draw in general is by using class definitions and ensure 'make al attributes by class' checked to keep the lineweights consistent and controlled throughout all drawings. This means a lot of classes. and especially if I am having different tones of black to denote items that are further away in lighter grey. Is there a way of applying a tile to an object but making it take on the destination class properties?
Anybody got any ideas?
I'm not sure where to aim this topic but am hoping to figure out how best to get the result of the attached drawing made by a friend. After all line work in my drawings I would like to add 'texture' too the drawing to show different earth build up, vegetation, wear on the solid surfaces etc. Sand, concrete and plaster hatches get me so far in creating texture but the drawing below has a range of different 'groups of polygons' that can be abstracted one by one when digging through the dwg drawing but is very heavy and very very slow. This drawing was created on autocad and somehow the program can handle this large amount of linework. A large batch of the desired linework is pasted over the drawing and then a 'wipeout' tool is used to mask off any undesired areas. Also attached are some examples of the linework when extracted from the overall drawing illlustrating the kind of linework as I have ben trying to figure out if this sort of stuff can somehow be translated into a hatch of tile etc. If so where can I find these more rugged natural hatches etc.? Cheers a delicate balance.pdf
Cheers guys, I'm not a massive fan of the sketch mode but I can see how it can be useful. Making a new line type couldn't be easier- thanks
This goes against the purpose of vectorworks defining the line to its most accurate but I wondered it a line type can be created that is crinkly? I've attached an image of different lines I have drawn with the polygon tool but wonder if there is already a tool for this madness?
Create new class with attributes of selected object
collins replied to michaelk's question in Wishlist - Feature and Content Requests
This place saves my life. Thank you -
This sounds brilliant and just what I've been looking for. However, can somebody please break down exactly what is necessary to install this from downloading the 'New Class From Object Script II.vwx' file @michaelk posted as I've used scripts etc. -
I've got this issue and have tried: -switching workspace -undocking object info palette I am downloading 2021 as I type this but it would be great if you know of a fix
Hi Justine, Did this work for you?
I didn’t find a solution to my 2015 MacBook and just presumed the graphics card was not up to it. I still get the grey screen but would love to know the actual solution.
Yes, definitely. I have tried re-referencing everything but it's still enlarging itself on the different scale. I have just created a duplicate but will need to find out what is not working later.
This might be a basic one but a question about hatches; I am using a hatch on a plot file at 1:500 and then the same hatch on a plot file at 1:50 which I would like to scale according to world units. It has been assigned to separate classes in their appropriate class plot files that I reference in to determine the output of all linework. However the hatch is not adjusting itself according to 'world units' depending on the output plot file/ sheet scale. The hatch is perfect for use on 1:500 but on my 1:50 the hatch scale is much too large. What am I doing wrong here?
Thanks Pat, yes, I had the Viewport on the wrong layer ... sometimes it feels like the movie inception
Hi, "vectorworks one or more viewports have been removed from the referenced layer name xxx; viewports are not supported on referenced layers when the referencing method is layer import" I get this method whenever I update my referenced files and am sure it says the solution in the message but I can't find out what is the issue. What is the problem? Thanks
Yeah, I find it a laborious process creating the hatches in a separate file, then assigning them to the new class in another file. Because invariably you want to test and edit the hatch according to the destination file. Yes, I saw another thread that requested the creation of a new class from the object selected with the right click menu. This would be ideal.
