Magi
Content Count
15 -
Community Reputation
0 NeutralAbout Magi
Rank
Greenhorn
Personal Information
Location
Poland
Recent Profile Visitors
Hi, Above article was written in 2018. Is this way of working with origins still recommended? Do they still apply to the current version? Automated import of georeferenced files is placing internal origin and the page far away from the designed object. The best way to preserve the coordinates is to move user origin to the designed object, leaving the internal origin intact, then to perform design work as usually. When the work is finished it is very easy to move back user origin to its original position to export file with correct coordinates. The article above recommends something contrary: moving design to page (internal origin) simultaneously placing user origin in a new position to place internal origin in the new place. Do we still need to move design to the page or is it enough to move user origins to the design?
Hello Nina, Thank you very much! I hope that this problem will be solved soon. I can send you some example file - if you want to survey the issue but i'm not sure it would necessary since you have described it accurately. As I'm aware so far dwf format is required by Municipal Authorities in many countries (Israel, Portugal, etc.) and this functionality shortage is really hurting Vectorworks position there. my email: magdalena@designexpress.eu Greetings, Magi
Hi, I have the same issue. Does anybody have any solution for correct dwf export from Vectorworks? .... Maybe some tips?
Hi Nina, I have the same issue as above. I'm trying to export to dwf a sheet 5000x900 mm. It seems that the biggest result I'm able to obtain is 1219,2 x 914,4 mm. Are there any sheet size limitation? Please look into attached prt-scr. Sheet size in Vectorowrks was set to 5000x900mm - the result export size is visible in the upper left corner. Entire drawing is clipped to this size. Could you help me please? BTW: Israeli authorities still requires dwf format. Magda
Thank you very much! Your answer was very useful! Greetings! Magi
Hi, I'm tring to import Revit files but the result is not fully satisfying. So I have the same question as hihosilvey. Could someone share with us some info about the best practices in Revit files importing?
I'm on Windows
JMcG, how did you do that? I'm sure the file I was trying to open was made in Revit 2018 or 2019 - and the situation was like described before.
I have the same problem. Any info on that subject?
I agree. Nevertheless, I continue to explore 2019 subdivision and found that bridge mode is not working for me for 3D shapes. I created two separate tubes, opened their ends, combined them together and tried to bridge the edges. No result. Does anyone know what am I doing wrong?
Does it mean that primary subdivision object was converted to solid for subtracting than again turned to subdivision?
Hi, I tried to reproduce fundamentals 2019 movie organic wall form but it seems to be impossible. Is there anyone who is able to tell me how to create that stepped open space inside the "wall"?
Nodes Available on the Marionette Resource Share Forum
Magi replied to Marissa Farrell's topic in Resource Share - Marionette
Hi, I'm not able to use any of that (below) files in 2017 version. 161003 Various collected nodes.zip All of the nodes in collection were made in 2016 VW - it seems that 3017 is somehow not opening them. Can anyone help me please?
