inikolova
Vectorworks, Inc Employee
    868
Posts posted by inikolova
  1. Hi @Jon wat,
    Are you submitting the .vwx for PDF generation from Nomad, i.e. for processing on the cloud? Only PDFs generated by the cloud contain measure data. Also, measuring works for top/plan viewports. Here is the Help article for this functionality: Ifhttps://cloud.vectorworks.net/portal/help/pages/measure-and-mark-up-pdf-files/. If you still can't get it to work, please let me know and I will try to help you further.
    Best regards,
    Iskra Nikolova
  2. Hi @Tim Harland,
    I am sorry to hear that you are having issues with referenced geometry. There are a few prerequisites for referenced files to work on the Cloud:
    1. The referenced files must be uploaded to the same storage location as the master .vwx file.
    For example, if your master .vwx file is saved on Vectorworks Cloud Services storage, the referenced files must already be uploaded at the time you submit the master file for processing.
    For example if your .vwx file is saved on your Desktop and you submit it for Publishing on the cloud, the referenced files won't be uploaded, so the cloud rendering would not contain the geometry, unless your master .vwx file contains the saved reference cache.
    2. Both the master and the referenced files need to be converted to the latest Vectorworks file version (which is 2023 currently).
    For example, if your .vwx file is created in Vectorworks 2022, you can submit it for processing, but the Vectorworks 2023 running on the Cloud won't be able to use your referenced files even if they are uploaded to the same storage, because they are an older version.
    I hope that helps.
    Please let me know if I can assist you further in any way.
    Best regards,
    Iskra Nikolova
    • Like 1
  3. Hello @jnr,
    It is expected for the 3D model to contain all objects that are visible at the time of the export. I cannot think of anything that would cause this behavior by design. I looked at prior jobs on our servers and I think you are not using the clip cube export settings, so you should be able to see all visible geometry in your model. Your files appear to be coming from Dropbox storage though. I wonder if somehow Dropbox could be sending us an older version of your file to complete the job with? Would you mind uploading a copy of your file to cloud.vectorworks.net, and see if the 3D model gets generated successfully from there? That would at least give us an idea if it is a Dropbox specific issue, or an issue with the export in general.
    Thanks,
    Iskra Nikolova
  4. I just got a tip from our Project sharing pro 🙂 . You change the visibilities in your Working File and Save & Commit. In the commit dialog, you have to make sure you choose to commit “view settings”. Note: only users with Project permissions or higher can commit view changes.
    I haven't tried this yet, but I thought I would share so you can try also. Maybe it will work for what you are trying to do.
    • Like 1
  5. Hi @Christiaan,
    Thanks for pointing that out! I will look into it. To be honest, I am not sure how the visibility of objects is set in the project file. I need to investigate and get back to you (and also update the Help article).
    Perhaps you can try refreshing your working file to be up to date with the project file and then generate the 3D model from there, to set the correct object visibilities?
    Best regards,
    Iskra
    • Like 1
  6. Hi @Carla A,
    I am sorry to hear that you are having issues with the Cloud. Please let me know the username of the account that is experiencing this problem in a personal message (or email me at inikolova@vectorworks.net), and I will investigate.
    Best regards,
    Iskra Nikolova
  7. On 1/3/2023 at 2:49 PM, kwik said:
    Any ideas?
    The Cloud just had a new version deployed. Can you please retry to see if it works now? I tried to reproduce your issue by naming other files the way you have named yours and I was not able to reproduce the problem. I'll continue investigating if it is still not working for you.
    Best regards,
    Iskra Nikolova
    • Like 3
  8. @Oaktown,
    I am sorry you are having difficulties making it work.
    I suspect it's returning "No such xattr: com.apple.quarantine" because the quarantine has already been removed.
    Please make sure you are correctly replacing the current files in the Vectorworks installation folder with the ones provided in the zip.
    Vectorworks Remote.vwlibrary should go to: Plug-ins
    The contents of the VWRemoteServer.framework folder should replace the contents of the Plug-ins/VWRemoteServer.framework folder
    Make sure the old ones are completely removed from the Vectorworks installation folder.
    We tried this .zip on a few machines and it worked on all of them, so I really hope it will work for yours too. By the way, these are for Vectorworks 2023. Are you trying with a prior version by any chance?
    Best regards,
    Iskra Nikolova
    • Like 1
  9. @Oaktown
    Please unzip the attached file and drag its contents into the Vectorworks Plug-Ins folder, replacing the existing ones. This should be able to fix the Remote crash.
    Note, you need to run the Quarantine command as follows:
    -In Terminal type:     xattr -d com.apple.quarantine     make sure there is a space, after ‘quarantine’, then drag the attached .zip file into the Terminal window and press <return>
    -Unzip the file using the Mac operating system's decompression option, do not use another decompression utility.
    Please let me know if this doesn't work for you.
    Best regards,
    Iskra Nikolova
    Remote plugin M1 fix.zip
    • Like 1
  10. @Peter W Flint,
    I am glad you are now getting the proper result! Yay!!!
    I think the reason why you had these mappings on the Cloud was that you had them in your local Vectorworks mappings. You probably opened a file that contained these fonts before you had them installed on your machine. And when you submit a job to the cloud, your local mappings are automatically synced to the Cloud.
    Best regards,
    Iskra Nikolova
  11. @Peter W Flint,
    I investigated this in more detail and here is what I think is the cause of your problem.
    During file generation, the cloud server searches for fonts using the following priority:
    1. Cloud server system fonts
    2. Current font mappings in your cloud preferences
    3. Custom fonts that you have uploaded to cloud storage
    It looks like the Yantramanav font you are using is currently mapped to Arial in your cloud font mappings.Screenshot 2022-11-17 at 8.27.55 PM.png
    To fix this, you need to delete these font mappings from your Vectorworks. In the Vectorworks preferences; on the Display tab, click the Edit Font Mappings button, and delete these mappings. Quit Vectorworks to save the font mapping preferences. After this, open the Vectorworks Cloud Services settings and click the SYNC button to sync your local mappings to the cloud.
    Go to https://cloud.vectorworks.net/portal/account/ and make sure these font mappings have disappeared.
    After this, the Cloud Publish should be able to give you the expected result.
    Please let me know if this doesn't help.
    Best regards,
    Iskra Nikolova
    • Like 2
  12. 3 hours ago, Peter W Flint said:
    Philosophically, I think a product that asks for a significant investment from its users should work as it is advertised.
    I agree with you. The issue you are seeing is likely due to some specific properties of the font you are using. I will do more research and try to help with your specific situation.
    • Like 1
