Tim Harland
114 -
Everything posted by Tim Harland
Is there any way to get the Drawing/Sheet Number Box to scale with a longer Viewport Number and/or Sheet Number (similar to how the Drawing Title adjusts to fit longer text) and to shift the drawing Title and Scale in the Drawing to the right in the Label Square style?
I have a file with referenced Design Layer Viewports, I have applied Viewport Styles to the viewports with class colour overrides, however after I update the reference the class colour overrides disappear, I have to 'kick the tyres' by applying a different viewport style and then reapplying the style I want to use. Has anyone else seen this behavior?
Linking Record formats to referenced Excel worksheets
Tim Harland replied to Tim Harland's topic in General Discussion
Hi Luca, yes I'll pull something together - I suspect what we are after is going more on the direction of the SQLITE Databases post that was in a recent newsletter, albeit even in those videos it didn't seem to be possible to link back out to the database from record fields. -
Thanks @Tom W. that coffee break was quite helpful - I must have missed it. HI @Luka Stefanovic OK that is good to know it can be done. It wouldn't just be for formating, we would also use it for data entry, especially as it is much quicker and less destructive to filter lists in excel. There are also still advantages to formatting in excel (printing over multiple pages for instance, adding headers & footers, printing headers on multiple pages) unless there are additional printing option for worksheets that I have missed in the last few versions? It is also necessary for excahnging information with clients and consultants. As far as I understand it from your Coffee Break, we would have to have a referenced version of the Excel Schedule that is linked to a Database worksheet (eg. via the Door number or a Door Type). But all the information about the item being scheduled would have to be just in the excel file - we wouldn't be able to have the information about the item as a record field in the symbol? In the coffee break example would it have been possible to change any of the information about the sanitaryware products within vectorworks? I guess it would be possible in the refenced Excel file, but not in the Database worksheet? So again in that example you wouldn't be able to select all sanitary objects from a particular manufacturer, or with a particular finish? In your example would it have been possible to list all the objects indivually and add other information from a record format eg Layer or class or a record format attached to the symbol? That could potentially work for us. What would be most useful for us would be to be able to for instance change the fire rating of a door in vectorworks and then update the excel version of our door schedule to reflect this without having to do an export. Of course it would be amazing if we could also make changes in the excel that would be reflected in the vectorworks file but I can see how that is technically very challenging and would essentially need a permanet connection to the vectorwokrs file to know the state of all the objects that were being scheduled. -
I am starting to explore the new excel referencing in Vectorworks 2024. Am I correct in thinking that only 'dumb' / self contained worksheets can be referenced, ie if we have a worksheet with database rows and or fields that are reading information from record formats there is no way to link them to an excel file? This seems to limit the benefits of this new feature significantly if the worksheet can't take advantage of the data contained within the vectorworks file? Or am I missing how to do this? How I had hoped this feature would work when I saw it announced would have been; that when have for instance our door schedule generated with information from our door symbols, that we would have been able to link that schedule to an excel file where we could format it more easily and use the filtering funtion in excel to interact with our schedule, and any changes in the vectorworks files would be reflected in the excel file. In an ideal world we would also be able to update any fields not linked to the geometry or location of the object.
We often reference multiple models together for out final renderings - to test variations and add people and lighting without making our core model files to cumbersome. However we cannot render files with referenced elements using the cloud referencing service, only the elements that are in the actual file are referenced. It would be good if cloud rendering recognised that elements are referenced and copied them over to the cloud too - doing this manually is too cumbersome.
Is it possible to have an new elevation benchmark set to use class settings for its graphic attributes? I'd like to be able to set the one benchmark style on different classes with different colours but as far as I can see you have to fix the class of the graphics in the benchmark style and when you place the benchmark there is no way of controling which class it is on?
When we attempt to use cloud rendering on 3D models where certain elements are referenced into the file using tradititional referencing, the referenced elements are not rendered?
Does anyone know if this has been addressed in VW 2023?
Show Door/Window Heights in SIA Dimensions
Tim Harland posted a question in Wishlist - Feature and Content Requests
IN the German version of Vectorworks it is possible to show the heights of doors or windows directly in associative dimensions (see the video here for a demonstration). When selecting the SIA Dimension type the Height of the openings is shown greyed out in the dimension info box but there is no way to get the dimension to show this information. That is very confusing for our users as they can see that the dimension recognises the height of the opening but can't work out how to get it to show up. We have a work around using data tags but that is a bit clunky especially when you adjust the offset of the dimension line. It feels like this would be a positive development for intelligent models especially seeing as there is already a tool available in a localised version. -
I've just seen that this is on the development roadmap, so not in 2023, but at least coming at some stage.
I take it in Vectorworks 2023 the only way to control textures on doors is via classes? This is still very problematic for us as we can't create additional classes for different materials.
It would be helpful (especially for staff less familiar with Worksheets) to be able to control criteria for Database Rows in Worksheets with And/Or functions through the visual interface. At the moment it defaults to 'or' (when one would expect it to be 'and') and the only way to adjust it is to edit the criteria formula to change the vertical bar to and ampersand. As soon as you want to add a new criteria you need to reedit the formula. In the same interface it would be good to be able to change the order of criteria or at least delete criteria that are not at the bottom of the list.
We also use layers (retained, demolition and new), with layer colour overrides in our sheet layer viewports, and retain a separate 'existing' plan than we can refer back to if things get messed up from too much changing back and forth between retained and demolition. We tend to stay in 2D for refurbishment projects though, doing the same in 3D is a real pain. At early stages we often just mask the existing until we are are more certain if the demolition is really happening. We don't use classes because you need triple the number and we already struggle to manage our existing classes, we also often have class systems defined by our clients. The biggest problem is when we export DWG's and there is no way to distinguish between the different states - for that purpose the class approach is definitely better. there is definitely no good system in Vectorworks at the moment, if you have well set up saved views it can function ok. I did here whispers that there was a new approach to demolition being developed but I haven't seen any evidence of it yet...? Hopefully something like the Archicad renovation filters: https://help.graphisoft.com/AC/24/INT/index.htm#t=_AC24_Help%2F050_ViewsVB%2F050_ViewsVB-122.htm
HI Zoomer, yes I can see your side of it too - is is quite a weird abstract thing to just have this window floating somewhere on a design layer. Like you say if you could see the aspect ration and lock the camera position that would also be a way to do it, the current approach seems very counterintuitive.
Does anyone know why in VW2022 enabling cropped perspective view is now relegated to a legacy 2D feature? We have always had it set as a default for all our files as otherwise whenever you enter a camera 3D view and zoom or pan around the camera gets moved (as well as being difficult to understand what exactly will appear in a sheet layer viewport from the camera as the proportions of the window don't necessarily reflect the proportions set in the camera). I don't want any of the other legacy features but have to have them tuned on to get the cropped perspective view - it makes me a bit worried as well as to how long the feature will last for into the future...?
We also only use Traditional Layer referencing based on initial testing of referenced DLVPs back in 2008 (and quite possibly also on Stevens advice at some stage or other). It does make managing certain files complicated due to the number of layers, but with filtering & layer tags it has become easier. I am finding that with the proliferation of styles for different objects - which often. don’t update in referenced files without a bit of a kick, as well as the introduction of data tags (which don’t work on referenced layers - but I guess also don’t work on referenced DLVPs either?) it is getting a bit more complicated to manage.
In the end I also just added another field to the titleblock and used it to filter my sheet list - main disadvantage is the potential discrepancy between the visible sheets based on the layer tags and what is listed in the worksheet but it definitely isn’t critical to our workflow.
found it
I would love this too, I am pretty sure I saw a post last we week wher eit was noted that this isn't possible, but I can't find it again.
Worksheet Criteria to search layer tags
Tim Harland replied to Ben Wingrove's topic in General Discussion
Thsi would be very helpful - we have a project divided into phases where I would like to be able to filter a worksheet (listing all the titleblock data) by the tags I have added to the sheet layers. I preseume it still isn't possible in VW 2021 or 2022?
