Kevin McAllister
5,191 -
Everything posted by Kevin McAllister
The Click Object to Offset button in the mode bar is gone in VW2010. Hold down the Command Key to select an object (not sure what the equivalent is on a PC). This also holds true for the mirror, rotate and move by point tools as well. KM
Help!: Warping 3D Text (True Type Polyline extrusion)
Kevin McAllister replied to huangfba's topic in Solids Modeling
Text Along a Path could get you close to a useable result (see attached image, you need to adjust the Rotate About Path angle in the OIP to make the text stand upright). The problem in this specific case is the size of the text vs. the degree of curve in the surface. Text Along a Path generates letters that are still flat planes, so letters the size needed would not follow the tight path. KM -
Depending on the content of the PDF, you can often ungroup it, delete the bitmap portion and be left with editable lines. KM
Ultimately there is no way to "bend" the letters in Vectorworks. Jonathan does list a few of the work arounds, but each has its drawback. To achieve this accurately I have done it in Rhino and imported it into a Vectorworks drawing. This would be a great wish list item. KM -
You could use Guides (submenu under the Modify menu). Guides can be turned on or off universally. Turn them off and they don't print. KM
My Wish List for VW2011
Kevin McAllister replied to Jershaun's question in Wishlist - Feature and Content Requests
Thomas, You can already create section viewports with a variety of section planes. While on a sheet layer, select a viewport and choose Create Section Viewport from the View menu. Depending on the view of the original viewport and the direction of the section line you can get almost any section you need. Realizing you can create section viewports from other viewports was a great discovery for me. Hopefully it helps you too. KM -
DLVP and Exporting to Sketchup
Kevin McAllister replied to John Meunier's topic in General Discussion
If you have one file that everything is referenced into, you could try saving it as a new version and then deleting the references. When you delete references, Vectorworks gives you the option to keep the referenced information in the file. This should give you a single file containing your entire project if I'm not mistaken. This file could then be exported to Sketchup. KM -
I find 2010 very stable as well. And there are some new features that are quite useful. Unfortunately in most cases bugs are found through unique situations of an individual task or setup. I can imagine its almost impossible to test for all of them. I have had good support from Nemetzchek whenever I have had a problem. A colleague of mine is working in Autocad on a file imported from Solidworks. He told me the file brought his machine down 29 times in one day..... conversely I have only had VW 2010 crash one or twice since installing it in late September. I doubt this is the norm for Autocad, but it does illustrate that all problems are relative to the situation, and that other platforms have similar challenges. KM
I used to use Bruce's method all the time, as it was part of my 2D workflow so it carried over when I began using 3D more heavily. You do need to be aware it can cause artifact lines if you are clipping a hole in the centre of a surface and rendering using Open GL. I have attached an example. Of interest, this is the first time I have done a side by side example in VW2010. I was surprised how differently the rendered line quality is from one method of 3D construction to another...... especially given the solid shapes are essentially the same. Kevin
Render Time Clock
Kevin McAllister replied to JSiegel's question in Wishlist - Feature and Content Requests
I second this wish. Even better if the progress bar also appeared below the dock icon for Vectorworks on a Mac. I often switch to other task while VW is rendering and an indication of progress would be great. Not sure if there is a PC equivalent to that.... -
I am wondering if I am missing something about the grid tool (Grid-Rectangular). Is there a way to create a grid with an odd number of squares, without having the odd square split as extra space at either end of the grid? It appears as though the grid is generated from its centre, so this will always be true unless there is a setting I am missing. I am originating my grid from the bottom left corner of an object. Thanks, Kevin
Ok, so I think this would be a very powerful feature to add to Vectorworks. Here's the scenario- Often there is a need to detail individual components of a model. If you build your model using symbols for individual components, there is no easy way at the moment to do a specific detail of each symbol component unless you separate them via layers or classes, so you can show only one instance. The wish - to be able to choose a symbol instead of a layer using the Layers button for a Viewport in the OIP. This would be much like the control given when you edit a symbol (ie. the Layer drop down shows the symbol as the layer). Then you could easily detail the symbol from any view. KM
How do you change z elevation values on individual 3D objects?
Kevin McAllister replied to Jules2009's topic in Site Design
Probably the easiest and most accurate way is to use Move 3D (By menu command Modify>Move>Move 3D or by keyboard Command+Option+m on a Mac). The dialog will allow you to enter a delta Z distance, either positive or negative. Alternately you could drag the object while in a front/back/side view. KM -
"Y" on the keyboard toggles the hints on and off. I find I sometimes hit it accidently when using "T" to force a red snapping acquisition box to appear. KM
Working Plane wishes
Kevin McAllister replied to michaelk's question in Wishlist - Feature and Content Requests
Michael, Make sure you discover the Working Plane menu items (Modify>Working Plane or in the right click contextual menu). You are now able to assign keyboard shortcuts to many of the functions, most notably Look at Working Plane. Its almost possible to work without the Working Planes Palette with the addition of the menu commands and the drop down Mike is referring to. I agree with your observations about the palette (as with some of the other orphan palettes, why don't the match in size, dock to each other etc.) but I suspect that the NNA solution is to make it obsolete. Kevin -
2d locus full screen guides, resource library
Kevin McAllister replied to taliho's topic in Architecture
Double click on the Object Snap icon in the top right hand corner of the Snaps Palette. Choose Smart Points. Make sure that Horizontal/Vertical Extensions and Extension Lines are checked. KM -
Advice on how to present a set visual
Kevin McAllister replied to Andrew Davies's topic in Rendering
Have you thought about taking a photo of a potential space it might tour to and using Camera Match ( ) to combine your model with the photo of the venue? Its been on my list to try for a while... KM -
I remember watching a tutorial demonstrating this in response to another post. Here is a link to it. It is the one about bent wire - http://www.vectortasks.com/Movies/Movies.html Ironically its from Pat's site.... KM
If the lines touch, use the Paint Bucket setting of the 2D Polygon Tool. KM
I'm honestly surprised that there isn't an online resource for this, where you can upload an early version file and it will post it back to you as a current version file. Legacy files are an issue and the lack of proper conversion tools only add to the every disappearing information problem.... KM
Thanks for the advice. I will give it a try. KM
Is there an easy way to map a texture across multiple objects so it feels like its a continuous image? Imagine something like one of those changing billboards where all the individual strips make a complete image. KM
This might help - http://techboard.nemetschek.net/ubbthreads/ubbthreads.php?ubb=showflat&Number=129548#Post129548 Use the Option (ALT I think on a PC) key to reverse the direction. KM
You could try: Modify>Convert>Convert to Nurbs Then Model>3D Powerpack>Stitch and Trim Surfaces If the objects form a closed shape they will become a generic solid. I am not sure if Stitch and Trim exists in Vectorworks 12. Kevin
This sounds like some sheets have been scaled in their individual Page Setup Dialogs. Right click on the offending sheet in the Navigation palette, choose Edit from the pop up menu and then Page Setup>Printer Setup and make sure scale is set to 100%. KM
