digitalcarbon Posted February 3, 2006 Share Posted February 3, 2006 i have a u shaped stair w/ no separation. i can not seem to get the upper stair to overlap the lower stair. i think the old stair tool could do it. am i missing something? Quote Link to comment
islandmon Posted February 3, 2006 Share Posted February 3, 2006 Have you tried to fudge the separation by using very slight spacing ... .0001" Quote Link to comment
digitalcarbon Posted February 3, 2006 Author Share Posted February 3, 2006 the problem is, there is no seperation input box as far as i can see. VW 11 had one but i cannot find it in 12. i must be over looking something. Quote Link to comment
CipesDesign Posted February 3, 2006 Share Posted February 3, 2006 You can make the adjustment as follows: go to SETINGS>FLIGHTS & PLATFORMS and set the width of "side 2". I think this will do the trick :-) Quote Link to comment
CipesDesign Posted February 4, 2006 Share Posted February 4, 2006 Hi Travis, you're most welcome. I value your tips as well! And yes, there are some things in 12 that take a bit of getting used to. You know what they say: "Change is good" (even though it is rarely ever easy!). Regards- Quote Link to comment
Peter Eichel Posted February 5, 2006 Share Posted February 5, 2006 Travis, Cipes and Armstrong, NNA should give you guys the CAD world equivalent of the Victoria Cross for services above and beyond! Keep those insights coming, please... Quote Link to comment
Travis Posted February 5, 2006 Share Posted February 5, 2006 Peter, I've needed that tip for weeks!! Thanks for your insight. Quote Link to comment
