alimcgpm Posted April 13, 2022 Share Posted April 13, 2022 (edited) Hi I'm hoping for a definitive answer on this as I have searched through the forum. I'm using VW2022 SP3 on a Mac Book Pro M1 Pro running Monetray 12.2. When using the shaded view (formely Open GL) I cannot get shadows to show even though it is checked in Shaded Options. Can ayone help please? Is there a global setting or a MacBook setting I can change. TIA Edited April 13, 2022 by alimcgpm spelling Quote Link to comment
0 Pat Stanford Posted April 13, 2022 Share Posted April 13, 2022 In Shaded, shadows need something to cast onto. That something has to be a 3D object. So if you have drawn a layer plane rectangle you will not see the shadows. Convert the rectangle to a 3D polygon and your shadows should show up. Quote Link to comment
0 markdd Posted April 13, 2022 Share Posted April 13, 2022 (edited) If you are using light objects, then need to enable shadows on the light object itself. Edited April 13, 2022 by markdd Quote Link to comment
0 alimcgpm Posted April 13, 2022 Author Share Posted April 13, 2022 13 minutes ago, Pat Stanford said: In Shaded, shadows need something to cast onto. That something has to be a 3D object. So if you have drawn a layer plane rectangle you will not see the shadows. Convert the rectangle to a 3D polygon and your shadows should show up. Yes it is 3D polygons. Still no shadows. Chair on stage etc. I am seeing ambient inclusion but no shadows. Quote Link to comment
0 markdd Posted April 13, 2022 Share Posted April 13, 2022 Are you using Spotlight Lighting Devices or Light Objects? Quote Link to comment
0 Pat Stanford Posted April 13, 2022 Share Posted April 13, 2022 Do you have the On Ground Only check box checked? If so, perhaps your shadows are "under" your 3D poly. Quote Link to comment
alimcgpm
Hi
TIA
spelling
5 answers to this question
