Platane Posted April 9, 2022 Share Posted April 9, 2022 Hello all, I can't enter in a script a manual Number to 'Space' here is my scrpit : PROCEDURE test; VAR hDraw : Handle; BEGIN BeginPoly; AddPoint(0, 0); AddPoint(0, 1000); AddPoint(1000, 1000); AddPoint(1000, 0); EndPoly; hDraw := CreateCustomObjectPath('space', LNewObj, nil); SetRField(hDraw, 'space', '11_Number Style','Manual'); SetRField(hDraw, 'space', '11_Space Name Cust', 'TheName'); SetRField(hDraw, 'space', '11_Proposed Area',Num2Str(0,200)); SetRField(hDraw, 'space', '11_Display Stamp','true'); SetRField(hDraw, 'space', '11_Number','AA101'); {this line is not process and event in a worksheet you can not ad manualy a text in field } End; RUn(test); Is it a known bug? Is there a other way to do it ? Thank's for your help Best day. Quote Link to comment
Pat Stanford Posted April 9, 2022 Share Posted April 9, 2022 Multiple different issues. This version ALMOST works. 1. You were setting the Number Style to 'Manual' instead of the required 'Label Text'. I also moved this line to the bottom of the script. 2. Once you set the Number Style to 'Label Text' you have to store the value into the field 'NumberLabelText' instead of '11_Number' 3. This is where it ALMOST works. The script below stores the proper values into the field, but the NumberLabelText does not display until you move (even a single pixel nudge is enough) the object. This has to occur (as best I can tell) OUTSIDE of the script. I have tried ever permutation of Redraw, RedrawAll, ResetObject, HMove(hDraw, 0, 0) I can think of inside the script and it does not seem to make the value display until it is nudged or otherwise reset outside of the script. A Move(0,0) outside of the script does for the reset. A Tools:Utilites:Reset All Plugins from the menu forces the redraw. Hopefully @michaelk@MullinRJ@Sam Jones or one of the other terrific scripters here can point out what we are both missing. PROCEDURE test; VAR hDraw : Handle; BEGIN BeginPoly; AddPoint(0, 0); AddPoint(0, 1000); AddPoint(1000, 1000); AddPoint(1000, 0); EndPoly; hDraw := CreateCustomObjectPath('space', LNewObj, nil); ResetObject(hDraw); SetRField(hDraw, 'space', '11_Space Name Cust', 'TheName'); SetRField(hDraw, 'space', '11_Proposed Area',Num2Str(0,200)); SetRField(hDraw, 'space', '11_Display Stamp','true'); SetRField(hDraw, 'space', 'NumberLabelText','AA101'); SetRField(hDraw, 'space', '11_Number Style','Label Text'); {this line is not process and event in a worksheet you can not ad manualy a text in field } End; RUn(test); Quote Link to comment
Sam Jones Posted April 9, 2022 Share Posted April 9, 2022 I'm no help here, and have run into this problem several times. In some commands, I have even thrown up an alert telling the user to nudge the object up and down to cause the OIP refresh. It would be fantastic if someone can tell us how to guarantee the refresh of the OIP when Redraw, RedrawAll, ResetObject, HMove don't do the job. Quote Link to comment
Platane Posted April 9, 2022 Author Share Posted April 9, 2022 (edited) Thanks @Pat Stanford you give me the way Now it's working if I do this PROCEDURE test; VAR hDraw : Handle; BEGIN BeginPoly; AddPoint(0, 0); AddPoint(0, 1000); AddPoint(1000, 1000); AddPoint(1000, 0); EndPoly; hDraw := CreateCustomObjectPath('space', LNewObj, nil); ResetObject(hDraw); SetRField(hDraw, 'space', '11_Space Name Cust', 'TheName'); SetRField(hDraw, 'space', '11_Proposed Area',Num2Str(0,200)); SetRField(hDraw, 'space', '11_Display Stamp','true'); SetRField(hDraw, 'space', 'NumberLabelText','AA101'); SetRField(hDraw, 'space', '11_Number Style','Manual'); End; RUn(test); Edited April 9, 2022 by Platane Quote Link to comment
