hollister design Studio Posted March 10, 2022 Share Posted March 10, 2022 I just had a pretty serious PDF and Hatch issue arise. I sent a PDF to a contractor. Everything looked fine but when he printed the file (reduced from 24x36 to 8.5x11) some of the diagonal hatches 'skipped' (see screen shot of PDF and photo of printed below) It seemed like they skipped when there was a dotted line over the hatched object. This caused confusion ("is this a surface detail? is this a material change?") and lead to an onsite meeting with a frustrated contractor.... I tested this and printed the file in office and the hatches skipped on my printer as well. Any thoughts on what's going on and how to prevent it in the future? Screen shot - everything looks good: Photo of printed copy with skipping hatch - notice the bottom hatch printed fine: Quote Link to comment
0 line-weight Posted March 10, 2022 Share Posted March 10, 2022 If you export the pdf at the size you actually want to print it at (so the printer is printing the PDF at 100% scale) does the problem go away? Quote Link to comment
0 hollister design Studio Posted February 10, 2023 Author Share Posted February 10, 2023 @line-weight sorry I never got back to this - I am still getting these misprints. And yes, getting this with no reduction (like in the last post) and printed at 100%. Here is a comparison as printed on my in-house printers at full scale: SC-T3170 printed at 24x36 - Brother printed on 8.5x11 but at 100% Also getting this hatching error from our Blueprint shop printed at 24x36 100% - not sure what machine they are using. I had one client say that they could not get them printed at all at the local kinkos - probably a separate issue - the blue print shop has had no issues with printing. I'm using the Publish command. Here are my settings: Thoughts? Quote Link to comment
0 Jeff Prince Posted February 11, 2023 Share Posted February 11, 2023 @hollister design Studio Share a file VWX and PDF exhibiting the problem and I'll take a look at it. Quote Link to comment
0 hollister design Studio Posted February 13, 2023 Author Share Posted February 13, 2023 @jeff prince Thanks, I'll see if I can find a smaller file. If not I'll upload this one. This is the error I get from Acrobat: Not sure if that is at all relevant. Quote Link to comment
0 hollister design Studio Posted February 15, 2023 Author Share Posted February 15, 2023 I copied out the geometry into a new document. I made a new sheet published to letter size pdf printed 100% on letter sized and am still having some hatch issues - but not quite as bad. I also found I had some of the "problem hatches" were set with less than 100% opacity. I set these to 100% and all the hatches printed better but not perfect. This is the "Hatch Test" sheet on the attached file. THEN I copy/pasted the worst problem viewportfrom the original file into the test file. This viewport still prints with very wrong hatches - just like main file. This is the "Hatch Test 2" sheet on the attached file. Hatch test 2 pdf: Hatch test 2 Printed: @jeff prince I've attached the small test file Hatch test.vwx Thanks for any thoughts. Quote Link to comment
0 Jeff Prince Posted April 15, 2023 Share Posted April 15, 2023 @hollister design Studio did you ever figure this out? I made a PDF from your VWX today and took it to my print shop and everything looks fine. I use a Mac and the built in PDF driver. I bet it has something to do with your PDF software. Sorry it took so long to get back to you, finally had a need to go the printer 🙂 Quote Link to comment
0 hollister design Studio Posted April 17, 2023 Author Share Posted April 17, 2023 Thanks @jeff prince Odd because I'm using Adobe Acrobat Pro - but it does always say that there are errors in the creation of the pdf file. Maybe vectorworks and adobe don't play well together... Here is the error that pops up with EVERY Vectorworks created PDF (and with no other (ie word, excel, indesign, photoshop, etc.) programs PDFs): Thanks for the test flight! 1 Quote Link to comment
0 Jeff Prince Posted April 17, 2023 Share Posted April 17, 2023 2 minutes ago, hollister design Studio said: Thanks @jeff prince Odd because I'm using Adobe Acrobat Pro - but it does always say that there are errors in the creation of the pdf file. Maybe vectorworks and adobe don't play well together... Here is the error that pops up with EVERY Vectorworks created PDF (and with no other (ie word, excel, indesign, photoshop, etc.) programs PDFs): Thanks for the test flight! The solution probably has you going into Adobe Acrobat Pro and changing some settings. Back when I used AutoCAD I remember having to spend days configuring Acrobat to make it work. Simple drawings were never a problem, but multiple objects overlaid and then viewed through a viewport work send Acrobat into a tail spin if the settings were off. I'm sure it better now, that was a long time ago... but could be related. Quote Link to comment
8 answers to this question
