fuberator Posted November 2, 2021 Share Posted November 2, 2021 Hello Is there a way to use dynamic parameters in the OIP? For example I would like to control the extrusion depth of multiple objects. Thank you Quote Link to comment
P Retondo Posted November 2, 2021 Share Posted November 2, 2021 I believe you have to get into Marionette and Python scripting for those advanced capabilities. Quote Link to comment
Vectorworks, Inc Employee Martyn Horne Posted November 2, 2021 Vectorworks, Inc Employee Share Posted November 2, 2021 As the previous response suggested, you may need to get into Marionette. I may be oversimplifying your requirement, but in the example you gave, if you select the desired extruded objects, and type in a new extrusion height, the selected objects will all change to the new extrusion depth. Quote Link to comment
Art V Posted November 2, 2021 Share Posted November 2, 2021 Or... VW could license the Parasolid kernel 3D constraints/parametrics so that it is a bit easier to create straightforward parametric objects without having to get into Marionette or scripting. For more complex objects scripting will still be necessary though. Quote Link to comment
Vectorworks, Inc Employee Martyn Horne Posted November 3, 2021 Vectorworks, Inc Employee Share Posted November 3, 2021 Quote VW could license the Parasolid kernel 3D constraints/parametrics so that it is a bit easier to create straightforward parametric objects without having to get into Marionette or scripting. Great suggestion - I'm sure our Roadmapping Room team members would be happy to discuss this with you during our Vectorworks Design Summit Open House day today. Perhaps we'll see you there Art V - everyone welcome. https://www3.vectorworks.net/vectorworks-designsummit-registration Quote Link to comment
Art V Posted November 3, 2021 Share Posted November 3, 2021 @Martyn Horne Thanks for the invite. I noticed you are using zoom for this summit which unfortunately is a bit tricky to use on my setup as it seems to confict with some other installed software. By the time that gets solved the summit is probably over so I'll use the forum roadmap section for this 3D constraints topic. 1 Quote Link to comment
fuberator Posted November 4, 2021 Author Share Posted November 4, 2021 @P Retondo I will look into that. Thanks Quote Link to comment
