Calculated Control Point
Not sure if this is possible, and I've probably asked this before, but here's a another try!
In a parametric object I want to calculate a point, put a control point there and draw some geometry located at that control point.  I get the first part, but when the user moves the control point the object is moving but not the handle.
Is this even possible?
Thanks!
Procedure Test;
CONST
	CR 					= 	CHR(13);
	GiveMeAnX			=	500mm;
	GiveMeAY			=	200mm;
VAR
	objHd,recHd,wallHd,
	ControlGeometry
													: HANDLE;
	resultStatus
													: BOOLEAN;
	objName, currentClass
													: STRING;
	i
													: INTEGER;
BEGIN
	PushAttrs;
	currentClass := ActiveClass;
	resultStatus := GetCustomObjectInfo(objName,objHd,recHd,wallHd);
	ControlGeometry := GetCustomObjectPath(objHd);
	SetObjectVariableBoolean(objHd, 800, TRUE);
	RectangleN(	0,0,
				1,0,
				GiveMeAnX,GiveMeAY);
	SetRField(objHd,GetName(recHd),'ControlPoint01X',Num2StrF(GiveMeAnX));
	SetRField(objHd,GetName(recHd),'ControlPoint01Y',Num2StrF(GiveMeAY));
	RectangleN(	pControlPoint01X,pControlPoint01Y,
				1,1,
				20mm,20mm);
	NameClass(currentClass);
	PopAttrs;
END;
RUN(Test);
Test 1 2 3.vso
Your GiveMeAX and GiveNeAY are constants. You don’t read the ControlPoint values.
Try this (I did this on my iPhone so there are no indents):
Procedure Test;
CONST
CR = CHR(13);
VAR
objHd,recHd,wallHd, ControlGeometry : HANDLE;
resultStatus : BOOLEAN;
objName, currentClass : STRING;
i : INTEGER;
rX, rY: REAL;
BEGIN
PushAttrs;
rX := pControlPoint01X;
rY := pControlPoint02Y;
RectangleN( 0, 0, 1, 0, rX, rY);
RectangleN( rX, rY, 1, 1, 20mm, 20mm);
PopAttrs;
END;
RUN(Test);
I think the part you are missing is that you have to write the Control Point values back to the parameters at the end of the script.  Look at Reading the parameters at the top and writing them back at the bottom.
Procedure Test;
CONST
	CR 					= 	CHR(13);
	GiveMeAnX			=	500mm;
	GiveMeAY			=	200mm;
VAR
	objHd,recHd,wallHd,
	ControlGeometry
													: HANDLE;
	resultStatus
													: BOOLEAN;
													: STRING;
	i
													: INTEGER;
	workX, workY								: Real;
BEGIN
	PushAttrs;
{	ControlGeometry := GetCustomObjectPath(objHd);
			WorkX := pControlPoint01X;
			WorkY  := pControlPoint01Y;
{	RectangleN(	0,0,
				1,0,
				1,0,
	SetRField(objHd,GetName(recHd),'ControlPoint01X',Num2StrF(WorkX));
	SetRField(objHd,GetName(recHd),'ControlPoint01Y',Num2StrF(WorkY));
	PopAttrs;
END;
RUN(Test);
Thanks @Peter Vandewalle & @Pat Stanford.
Sorry for the slow replay.  I'm currently in Internetless Lakes.
The point GiveMeAnX,GiveMeAY is only meant to be the initial position of the control point.  It is calculated by the plugin - not defined in the plugin definitions.  After that I want the user to be able to move it around at will.  (The first rectangle is only there to remind me where the initial point was).
In your example, Peter, the control point starts out at it's definition point.  I want to specify the initial location from the script.
When I try your's Pat the diamond square moves but the control point doesn't follow it.
Is there a good way to assign an arbitrary location for a control point that is still moveable by the user?
I may have been barking up the wrong tree!
This does what I want:
Procedure Test;
CONST
	CR 					= 	CHR(13);
	GiveMeAnX			=	500mm;
	GiveMeAY			=	200mm;
VAR
	objHd,recHd,wallHd,
	ControlGeometry
													: HANDLE;
	resultStatus, UseDefaultPositions
													: BOOLEAN;
													: STRING;
BEGIN
	PushAttrs;
	RectangleN(	0,0,
				1,0,
	UseDefaultPositions := IsNewCustomObject(objName);
	IF UseDefaultPositions THEN
		BEGIN
		END;
				1,1,
				200mm,200mm);
	PopAttrs;
END;
RUN(Test);
Seems obvious now :-).  Thanks for your help Pat & Peter!
