hollister design Studio Posted June 7, 2021 Share Posted June 7, 2021 I want 'by class' hatch in Top/Plan and the 'by class' texture in 3D. It seems like an unstyled slab is the best option? I thought I could use 'Add 3D object to slab' for volume to match the pool shell if needed as thickness seems tied to the component stack. Side thought - Is there a way to pull volume for a worksheet? What do the long time users use? Quote Link to comment
Jeff Prince Posted June 8, 2021 Share Posted June 8, 2021 @hollister design Studio I just extrude the pool shape about 1" to create the water plane. Autohybrid for your desired 2D appearance. I wouldn't recommend using a slab for water personally, far easier to control the geometry using modeling tools if you need to actually fill the pool with virtual water 🙂 1 Quote Link to comment
bcd Posted June 8, 2021 Share Posted June 8, 2021 How have you modelled the pool? Chances are a solid intersection with a generating (pre shell) object and solid subtractoion of the pool shell with get it exactly. Quote Link to comment
hollister design Studio Posted June 8, 2021 Author Share Posted June 8, 2021 Thanks guys @bcd But won't that leave me with an object that's transparent in Top/Plan? That does seem like it will get me an exact volume if I needed it though. @jeff prince I have been making Autohybrids - but I feel like they're messy. Hard to edit, a pain to ungroup, and always seemed to crash when I try and ungroup so I've stopped even trying. Fine if you're the type that designs it right the first time - but that's not my style! I like to flounder about a bit until I've found the right harmonies... ...and then make more changes because - well, just because. And then more floundering. Quote Link to comment
bcd Posted June 8, 2021 Share Posted June 8, 2021 9 hours ago, hollister design Studio said: But won't that leave me with an object that's transparent in Top/Plan? Yes, But you can Extract a Planar object for the pool surface & use it as the 2d componenet of a Hybrid Symbol together with the water solid if you don't want to go down the Auto-Hybrid route. AutoHybrid is actually decent enough in this single object case. But don't move it - and if you want to remake the volume simply Ungroup the AutoHybrid in a 3d view, discarding the 2d component, and rerun AutoHybrid when you're done. 2 Quote Link to comment
Jeff Prince Posted June 8, 2021 Share Posted June 8, 2021 @hollister design Studio 13 hours ago, hollister design Studio said: @jeff prince Fine if you're the type that designs it right the first time - but that's not my style! I like to flounder about a bit until I've found the right harmonies... ...and then make more changes because - well, just because. And then more floundering. It really has nothing to do with design and everything to do with craftsmanship in terms of tool usage. Quote Link to comment
hollister design Studio Posted June 8, 2021 Author Share Posted June 8, 2021 @jeff prince You should see my paintings... They take years and end up having three or four completed compositions buried as I move in different directions. I'm definitely a 'process' oriented person! 2 Quote Link to comment
