trashcan
Viewports Adding Sketch to Border?
Posted (edited)
This started happening a couple weeks ago and can't figure out why:
If I open the OIP I get this:
How do I turn this off?
Ahhh it seems that my Renderworks style is defaulting to sketch:
I don't want that, how do I change it?
Thanks
Edited by trashcan
clarity
9 answers to this question
When you create a viewport it will use whatever render mode is currently set on the design layer. So if all your VPs are being created using Sketch background render presumably that means that Sketch is set to be the current render mode on the design layer?
@Tom W. of course I can't recreate now. Thought that maybe my default template had Sketch set for its rendering in the design layer, but it does not. Very odd. I never use Sketch so perhaps a hotkey misstep at some point. If it comes up again I will dig in and take a look.
@Tom W. figured it out! The Sketch render mode has the same hotkey as "Save As" for nearly every other program on the planet, so I accidentally changed the render mode from GL to Sketch and then created my viewports while Sketch was the render mode.
I know. I am usually the one advocating to not customize workspaces. :-(
But in this case if your muscle memory is winning and you don't use Sketch very often, it is probably the better part of valor to just edit the workspace and remove the shortcut. Or even reassign it to where your muscles say it should be.  ;-)
Quick update - even though my viewport is set to openGL as it's background renderer, when I create objects in the annotations of the viewport it defaults them to some kind of sketch and I'm not sure why:
I've been going through and manually changing to "No Sketch" but that's getting old fast. Any ideas?
Do you possibly have the Foreground Render settings set to Sketch? or to Hidden Line with the Line Render Option to Sketch Hidden Line?
@Pat Stanford I can't find the offending viewport now, but none of my viewports have any kind of foreground rendering. All of them are Open GL and BG rendering. When it comes up again (which I'm sure it will), I'll loop back here.
