Tbai Posted January 6, 2021 Share Posted January 6, 2021 Hi Marionette geniuses! I wonder if there's an opposite node for or a way to workaround to untick/remove IFC entities that were previously attached to objects. Data Manager has been really helpful attach/manage new IFC data, but when I tried to remove any unwanted entity/data in Data Manager, they still remain in the Data tab in OIP. Only gave me the option to manually untick them in the OIP if this makes sense. I was hoping it can automatically unactivate removed entities...Data Manager is still under developing from what i read, hopefully this will get improved! I've checked the collection of various nodes shared by AlanW and tried searching across the forum, but got no luck. If it already exists, could you redirect me to the post please? Thanks in advance! Quote Link to comment
Gregi Posted January 9, 2021 Share Posted January 9, 2021 Is this what you are looking for? I do not work with the IFC-Data-thing, but think it should work. 2021-01-09_Del IFC Entity_gim.vwx Quote Link to comment
Tbai Posted January 9, 2021 Author Share Posted January 9, 2021 Hi @Gregi ! Thank you for creating this node! I gave it a test. It works perfectly to delete ALL IFC data attached to any objects. It's good to have this node too, but maybe I mis-interpreted what I'm looking for here...Each object got IFC data attached shows this nest of info/data below: The node you created ended up removing the entire IFC Data Set (tbh, the naming system is so confusing🤦♂️. The IFC Data Set and the first line IFC Entity (Property Set) both called the same...? not sure if I got it correct here) I'm looking for a node to remove or untick only 'ONE line' of IFC Entity/ Property Set (equivalent to a record? For example, to untick the line 'Classification' with all other still remain the same) Something like the opposite of the 'Set IFC Property' node maybe...? I guess the sIFCPropValue part would be redundant. Again, thanks for any help in advance! Quote Link to comment
Gregi Posted January 13, 2021 Share Posted January 13, 2021 (edited) Hi @Tbai I think this is what you need? In my test it returns true, if the PSet was connectet and false, if it wasn't 2021-01-13_Del IFC Property Set_gim.vwx Edited January 13, 2021 by Gregi 1 Quote Link to comment
Tbai Posted January 19, 2021 Author Share Posted January 19, 2021 Hey @Gregi, Thanks again for looking into this. Just had time to test it out. You were correct. Once I removed the propoerty set away from the pre-set data manager, it works like a charm! Much appreciated! Quote Link to comment
