Solid Subtraction Locked
waynelocke
7 answers to this question
Sorry, you probably have solution already.
Any chance that on the Object Info Palette it was showing up as Fillet or Chamfer?
I had much frustration with models that I had painstakingly filleted and then wanted to change the solid modelling. The only way to do it was go through and ungroup multiple times to get back to before the last fillet command...
Hi, I am currently having exactly this same issue with a drawing.  I have not found an answer and have tried everything from re-starting to copy and pasting the object into a new drawing and attempting to unlock it so I can add some fillets.  I can draft a new object in this same drawing and able to add fillets, etc. to it but not to the object I have spent many hours drafting.
Anyone had any luck sorting this out?
Thanks,
-Alex 🙂
