waynelocke
    13
Everything posted by waynelocke
  1. I'm sorry not to have included the OS. I am using the latest version of Mac Ventura but this has always happened since the installation in 2020. I solved the problem by deleting the file "net.nemetschek.vectorworks.plist" from the library as suggested in a post by by Jeremy Best in January 2022. Thanks
  2. This has gone on since upgrading to 2020 Fundamentals in 2020. Any Save dialogue box spans more than both my screens and the Save button is below the screen. I just have to say a "Hail Mary" and hit return to save. This is and has been a major irritant. Is there no fix for this? My software is the latest 2020 update.
  3. In the last month when I do a "Save As" the window spans more than the width of the monitor and the resize arrows allow only increasing the width not decreasing. I have to move the window to access Cancel or Save. I can change the vertical distance. Open is also larger than I would choose but although it is not full width + I cannot change the width. This only happens in Vectorworks (2020 Fundamentals) and not other programs.
  4. I have the exact same iMac (except 40 GB memory) and the same situation. I just changed the navigation graphics as suggested and will try resetting prefs if needs be. I am avidly following this thread.
  5. Is that in 2020 Fundamentals? This is what I have:
  6. I followed your advice and restarted VW 2020 then Copy and pasted into a new file. Same thing. What does solid subtraction locked mean? What is the purpose? Anyway here is the file. It is just a small item to 3d print. More aggravating than anything.HG_2.vwx Thanks for looking.
  7. Why and how did my solid subtraction become locked so that I cannot fillet the edges? How do I unlock it? I have right clicked and unlocked to no avail. I have also gone through all of the editing screens unlocking. What gives?
  8. I have been battling this same foe over the last few days. This may not work for you. I am dealing with a texture mapped obj model of a hand and fore arm. The texture mapping was lost with any cutting operation. I finally exported the file as a Rhino file and then imported it back in. The file was much larger and problematic but after sectioning it I exported as an obj.
  9. I have the original VW2010 installation disk which is registered to me. I sent you a private message with contact info. Wayne
  10. I have the original VW2010 installation disk which is registered to me. I sent you a private message with contact info. Wayne
  11. I have a copy of VW 2010 Fundementals with license which can be transfered
