vassen Posted October 20, 2020 Share Posted October 20, 2020 Hello everyone, if you guys could help out. i am trying to figure out why my window is not align with gray component in my wall style. May be i have not check some parameters in the VW file. Thanks Wall and windows 20102020.vwx Quote Link to comment
zoomer Posted October 20, 2020 Share Posted October 20, 2020 It should be Jamb thickness, could be by Wall width, which would fit into any Wall. But you may also want a controlled Offset for your Sash, so it my be better set Jamb manually and use more Styles for different Walls when necessary. 1 Quote Link to comment
Markvl Posted October 20, 2020 Share Posted October 20, 2020 (edited) Haha @zoomer beet me to it. Couple of things came to mind. 1. Considering how the door is sitting in relation to the wall. Perhaps your wall design (how you lade out the components) may have something to do with. or 2. See pic attached. @zoomer picked up on it. Perhaps your "Offset in Wall" needs to be filled in with the difference to push back the door system. Note: you can give that offset a negative distance to push it back or a positive distance to push it forward. Edited October 20, 2020 by Markvl 1 Quote Link to comment
vassen Posted October 20, 2020 Author Share Posted October 20, 2020 @Markvl @zoomer Thanks for your advice will look into it an revert back if everything working. Quote Link to comment
