I am not good enough in Python to know if it is a function problem or a python problem. The following seems like it should work, but the LgCrossC and ArrowC "constants" (defined internally to VS) don't seem to be recognized.
import vs
vs.SetCursor(LgCrossC);
down =False
while not down:
    down, pt=vs.MouseDown()
vs.SetCursor(ArrowC);
import vs
down =False
while not down:
Here is one that does work in VS.
Procedure Test;
Var	X1,Y1: Real;
Begin
	While Not Mousedown(X1,Y1) do
		Begin
		End;
	SetCursor(ArrowC);
End;
Run(Test);
I’m in the car right now so I can’t test but I would try with 0, 1, and so on. Or create a little loop with integers and an alert dialog...
Posted (edited)
1 hour ago, Pat Stanford said:
SetCursor(LgCrossC)
The python script it does not seem to accept the variable "LgCrossC" or "ArrowC" in python
I tried with numbers and I did not see any change in the cursor appearance.
import vs
integer = 6
down =False
while integer != 0:
	click = False #define click variable
	pt = 0 # define pt variable
	while not click: #waits for click
		click, pt = vs.MouseDown() #assigns coordinates to pt
	vs.SetCursor(integer)
	vs.Wait(2)
	vs.AlrtDialog(integer)
	integer = integer - 1
Also what does the "import vs" command do?  I can't find any documentation. It doesn't seem necessary for the script to work.
Edited by The Hamma
I thought that import vs is needed to allow Python to see all of the vectroscript commands. But again, I am not at all a Python guy.
Try:
1307 for LgCrossC
1308 for HandC
1309 for ArrowC
1310 for SmCrossC
1311 for WatchC
1312 for TextBarC
At least 1307 and 1309 work for me.
I got these from digging in the Vectorscript Reference.xml file that comes as part of the SDK.
Posted (edited)
Yes that works.
Thanks for the tip.  I downloaded the SDK.  Seems like this info should be written down in a better format thank looking through an XML file.
Edited by The Hamma
Posted (edited)
The 100 of us who are interested know where to look (or who to ask) so why document it better!  ;-)
Glad to help.
EDIT::  [For anyone who did not get it, this comment was SARCASM. Document Everything. Helps the new and helps the old. Even helps the VW new employees. Document everything.]
Edited by Pat Stanford
Sarcasm
This will display each for two seconds although the watch cursor does not appear to work on windows.
CrossInteger = 1307
Crossconfig = 'LgCrossC'
vs.AlrtDialog('Hit ok to see ', CrossInteger , ' = ' , Crossconfig, ' for 2 seconds')
vs.SetCursor(CrossInteger)
vs.Wait(2)
CrossInteger = 1308
Crossconfig = 'HandC'
vs.Wait(2)
CrossInteger = 1309
Crossconfig = 'ArrowC'
vs.Wait(2)
CrossInteger = 1310
Crossconfig = 'SmCross'
vs.Wait(2)
CrossInteger = 1311
Crossconfig = 'WatchC'
vs.Wait(2)
CrossInteger = 1312
Crossconfig = 'TextBarC'
vs.Wait(2)
Josh.   Put him on salary.
I figured it out, if you run the python script as an external script that is imported via another script the "import vs" is needed, but when run directly from within vectorworks it is not.
