Andy Broomell
Class for new Title Block Border objects?
Is there a way to set a Title Block Border object to always insert onto a particular class once it's been saved as a Style in the Resource Manager (like a red symbol)?
For example with regular symbols, under Symbol Options you can choose a class for that symbol to always insert onto. How can I do that with a TBB Plug-In Style? Currently it always inserts onto the active class.
@Nikolay Zhelyazkov
I don’t think you can.
I don’t know if it works for titleblock border styles but for detailer styles if the detailer object is on a particular class when the detailer style is created then it will insert into that class when dragged in from the RM.
TBB styles are a bit different however so not sure it would work wth them.
As I always have "none" as my active class a workaround which I use to quickly assign selected objects to a class is to use a script. I have several of them in an "Assign Class" script palette.
This one assigns objects to the none class but you can easily edit it to make it assign objects to the titleblock class if you wish. Just change the third line.
Procedure SetTheClass;
CONST
	kCName = 'None';
VAR
	gh1 : HANDLE;
Function DoIt(h1 : HANDLE) : BOOLEAN;
BEGIN
	SetClassN(h1, kCName, True);
END;
BEGIN
	Locus(0, 0);
	gh1 := LNewObj;
	ForEachObjectInList(DoIt, 2, 2, FInGroup(GetParent(gh1)));
	DelObject(gh1);
END;
Run(SetTheClass);
Hello @Andy Broomell,
@Boh is right. If you create new TBB style out of a TBB assigned to a class, when you insert objects of that style from the RM they are assigned to the specified class and not the active class. However, this works only for drag & drop from the RM. Creating the styled TBB from the tool takes the active class.
Best Regards,
Nikolay Zhelyazkov
@Boh love that script you posted!  Do you know of any way to make the script work on all nested objects in the selection?  Like if I had a group or symbol with different classes could I run script to make everything in that group or symbol go to the desired class?
Interesting that it only applies to drag & drop and not double click insertion. Good to know, thank you!
For what it's worth, my goal is simply to set up a template for others to use that's hard to mess up. I actually just leave TBBs on the None class, but in some other people's files I've recently seen a number of TBBs on the Dimension class (which was surely Active when the TBB was inserted) and therefore the borders were blue 😅
Edited by Andy Broomell
Glad you are finding it useful. Credit for the script goes to @Julian Carr who kindly wrote it for me.
Sorry I’m not a scripter so i have no idea how to edit it beyond changing the class it assigns to. I think there may be a script out there already that does something like what you want.
