ACopeland
Border & Title Block Rendering as Sketch
I had this issue on v2018 and now on v2020 (both educational, I'm a prof): When changing settings on the edit title block screen, after clicking OK, my information is there but the render of the title block and border is now rough sketch. When I try to change the Render on the Object Info tab, I get the options of different renders, including No Sketch. Selecting on this does not get rid of the sketch effect. The title blocks on other sheets are not effected; I can't copy and paste from another sheet without it becoming rendered in sketch. This only happens on the sheet I initially am on when I edit the title block-usually the first one-none of the others, even when I renter the editing screen on a different sheet. Is there another place the rendering setting can be changed? Does anyone else have this issue?
2 answers to this question
We just chased a bug with sketch. We found that items were not responding properly to custom sketch settings unless you hit the Preview button from the Sketch Options dialog box.
If it is sketching when you don't have Sketch Rendering turned on, I don't have any idea.
