›I have been working on two different 2020 files, both of which originally started in 2019.
I've had them both open all day, working on cleaning up my resources.
I discovered when I went to use LW Data Exchange that Absolute Address is not ...accessible?
Both files are set up exactly the same under Spotlight Preferences > Lighting Devices > Parameters - I even saved the working file's settings and used that in the broken file, to no avail. Screenshots below.
When I choose "Edit..." in Object Info for Lighting Devices, Absolute Address is visible, but it does not appear in Object Info.
And thus I cannot use LW Data Exchange.
Quitting and Reopening does not fix.
Repairing the Install does not fix.
Doing a Library update does not fix.
Exporting to 2019 and then opening into 2019 or 2020 does not fix.
Copy Pasting into a new Document DOES fix, but surely this isn't the only way?
In the working file:
In the "Broken" file:
- it is here, and selected under Lighting Device Parameters, but then is not an option in Lightwright or in the object info.
