Martin Crawford
Worksheet Formatting
How can I convert a mm dim to feet and inches. I can do the math and get a decimal number, however I would like to display as 10' 5 3/16"
I see there is a FormatField option as a function, however I am unable to find any documentation on how it works.
Thanks
Martin
Have you tried formatting the cell as a Dimension?
Worksheet Menu:Format:Cells...:Number Pane.  Dimension.
The style of the dimensions will be set in the Document Preferences.
That would be wonderful, except the drawing is in mm, and I am trying to convert to Feet - Inches and Fractions that Construction crew uses.
Thanks
Would you be willing to have one column showing the mm value and another showing the feet-inches? If so, I think we can come up with a work around.
When you scale this drawing set the value and aside the unit like:
actual distance: 36'30"
new distance: 80 m
